Originally posted by bucfan1234 No, I have the PDS finder, but I found myself wishing that I did have the waist level finder when I was out shooting the test roll.
I usually spot meter in addition to the in camera meter as well, but my results seem to fall far short of yours. Perhaps, in time, I will figure it all out.
The typical look at the highest and lowest values then find some average is a common exposure method. But I rarely use that anymore. I get it wrong now and then but for the most part the one-degree yields predictable tone placement to a satisfactory degree before you even take the picture without getting all scientific with it ( ie measuring negative densities with a densitometer).
Try this approach. Every roll try a few shots where you record your film, any filters and exposure. A scene that has a good light range is a good selection. Whatever exposure is selected, that is your middle gray exposure. About 3 stop below that, blacks should be really black and not have much detail seen on the negative using a light box and loupe. So record the EVs (if your spot meter reads in EV) of the darkest areas of the scene then visually compare those areas that are 3 EV less than the middle gray exposures EV on the negative.
If your development is good, those areas should produce pretty deep blacks (clear on the negative); otherwise, you need to adjust your development. When you can "place" a dark area near edge of lost detail, you are good-to-go. Now you can look at a high values in a scene and count how many stops they are from either that low value or the middle gray exposure and start to get a grip on when highlights start to get lost. Soon you'll get a feel for how many stops of light you can capture in a scene for that development and film.
When all that is finally working predictably most of the time, you can walk up to most scenes, look it over with your eyes and meter only one thing in it to get your exposure by placing it where you want it to fall relative to that middle gray exposure.
Originally posted by gofour3 Nice shots Tuco, Jussi & Wuzet! The weekend snow storm must have been fun!
Phil.
Thanks
