08-26-2013, 04:37 PM   #2236
wuzet's Avatar
PZ-1P, FA*24/2, Tri-X 400, Pyrocat HD
08-27-2013, 10:15 PM   #2237
Here are some recent ones. ME Super, Tri-X pushed to 800, K 35 3.5.
08-27-2013, 10:47 PM   #2238
arnold's Avatar
Here are some from quite recent to olden days. The scene at the table against the window back-light was a challenge for my first roll through a Franka Rolfix folding camera. It has an f4.5 schneider Radionar lens. I had to do some PP as I had not used a flash.
The remainder were taken in 1961 with a Kodak Retinette with a f3.5 Sneider Reomar lens. It too is a three element lens.
CanoScan 9000F  Photo
08-29-2013, 05:23 PM - 1 Like   #2239
gofour3's Avatar
Some Rollei Retro 80S shots. (KX & K15/3.5 and K35/3.5)
Phil.
08-29-2013, 06:50 PM   #2240
I like rollei retro 80s, but it looks like it has been developed for too long and you have blown highlights (it can be very tricky).
Next time you do it, I would reduce the development time and make sure the agitation is very gentle.
It took me 3-4 rolls to get the results I like.
08-29-2013, 07:23 PM   #2241
gofour3's Avatar
QuoteOriginally posted by Nuff Quote
It was Lab processed and scanned. I tweaked around the TIF files and saved them as JPEGS before I posted them, so it's probably my fault.
First time I've used this film, so not sure what the end result should look like. I got it cheep from a local store, so I figured I'd give it a try.
Phil.
08-29-2013, 07:38 PM   #2242
The agitation profile is a function of the developer and not the brand of film. Gentle/vigorous agitation slows down/speeds up the film for a given development time. Use development time to control it and follow the manufactures recommended agitation profile.
08-29-2013, 09:52 PM   #2243
QuoteOriginally posted by gofour3 Quote
Phil.
Well, if they used the official numbers, that's what they did wrong. I'm pretty sure the boats will look black on the negative. The official times are too long...
08-29-2013, 09:53 PM   #2244
Phil.
I have shot it a little and actually picked up a 100' roll. My initial rolls I developed in Edwal FG-7 1+15, though I don't recall the times. As mentioned above, gentle agitation helps temper the contrast. There is a white paper on the film (LINK, pdf) that recommends HC-110 dilution H* for 11 minutes at 24C (rate at EI 160). I have a roll waiting for processing and will let you all know how the HC-110 works.
A few photos...Rollei Retro 80s - a set on Flickr
The extended red sensitivity is its unusual characteristic. With appropriate filters it can be used for IR photography. Also good for nudes and portraiture and landscape.
* http://www.covingtoninnovations.com/hc110/
08-29-2013, 10:07 PM   #2245
What official numbers? There are entries on the Massive Dev Chart (B&W Film Developing Times | The Massive Dev Chart), but I have had poor luck with their numbers with other films.
08-29-2013, 10:16 PM   #2246
Curious, how do you know what developer his lab used?
08-29-2013, 10:33 PM   #2247
You can speed up/slow down your film through your exposure index. IMHO, that is better than playing with the agitation profile. Of course many developers are more tolerant to how gentle/vigorous you agitate than others. My PMK Pyro I often use, for example, is very sensitive to streaking and non-uniform development if you don't shake it enough. It's that way all the films I have used and I assume Retro 80 would be no exception.
08-29-2013, 10:50 PM   #2248
gofour3's Avatar
Thanks for the Retro 80S tips guys. I'll rescan a couple negatives with my home scanner to rule out scanning. I have one roll left and may try another lab for processing.
Phil.
08-29-2013, 11:00 PM   #2249
Phil.
I dunno, Phil, your first shot there with the boats looks pretty good both in tonal scale and contrast on my monitor. I think any further adjustments would be a matter of personal taste.
08-30-2013, 12:07 AM   #2250
I don't know which developer, but the times specified for rr80s for any developer are too long according to post by people from various sources.
For me the times in Rodinal and Xtol (replenished) were both too long. The xtol times
My xtol replenished times are usually between 1:1 and 1:2 mix on the official xtol data.
Here's the official data for rr80s Rollei RETRO 80S TWIN 2x 135-36
Massive dev chart: B&W Film Developing Times | The Massive Dev Chart
Similar data for 1:1 and 1:2 mixes.
From my experimenting I've arrived at my mix being 7min at 20C (I use 1:2 times for other films). That's 36% shorter time, even if I go by 1:1 times, that's 18% shorter times.
The photos look like the results I used to get with the official times.
Here's couple with my photos with the shorter dev time (i've posted them before):
autofocus, camera, d-76, dog, doubt, exposure, film, flickr, fp4, kiev, leak, lens, love, mine, minutes, nikkormat, pentax, phil, photography, pm, post, quality, roll, shot, shots, smc, sp500, station, steve, thanks
Travel Some B&W film shots from the Gulf of Gaeta, Italy Rense Post Your Photos! 3 04-23-2011 12:22 AM
First post - few b&w shots sealisthenewbeaver Photo Critique 2 09-22-2008 06:40 PM
My Pentax shots in print & film. blwnhr Photographic Technique 5 03-18-2008 05:13 PM
First shots with a zx-5 film camera (c&c welcome) jbrowning Post Your Photos! 2 12-23-2007 08:18 AM
All times are GMT -7. The time now is 03:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
