12-03-2014, 11:15 AM - 1 Like   #3571
45 Mike's Avatar
Yep, I do B/W and C-41 process myself. It is *not* difficult nor is it all that dependent on microsecond and microdegree accuracy.
I use the Unicolor one liter kit from Freestyle.com. I started using it in March of 2014, I have run about 6 rolls of 135 film, and close to 15 rolls of 120 film. I still get great results. I do not use 102 F temp at 3.5 min, I use 95 F @ 6 min. At the lower temp the time is much less critical.
I fill a 6-pack cooler with hot tap water, and set the C41 and Blix in the bath, and when the C41 gets to 95 F I pull it and the Blix.
Then I process. The temp of Blix is not critical. I never worry about keeping the tank in a bath at temp, at the lower temp, the temp is not all that critical either. :-)
Now, if you expect perfect results, you can do it yourself, follow the directions exactly. Or you can trust someone else to do it right.
Or you can accept that nothing is perfect and do what I do, and be happy that someone else did not screw up your award winning film shot.
12-03-2014, 01:35 PM   #3572
Cuthbert's Avatar
Guys I never developed a film in all my life, when I was young in the 90s there were C41 labs at any angle of the street, today they are all disappearing and the few that remain either work very badly or they charge you ridiculous amount of money (in Italy I was asked 24 euros for a 36 exposure C41 roll!) so ideally I would like to become "independant"..I was always told developing C 41 at home is either impossible or the results are disappointing.
12-03-2014, 02:02 PM   #3573
eddie1960's Avatar
QuoteOriginally posted by Cuthbert Quote
In some ways it's easier than B/W processing. With B/W you have a myriad of chemical choices all of which cause a different end result in the neg. With c41 it's very straightforward, the choice is limited and the main thing is temperature control for a few minutes. If you are going to print then it's a different story, you will need a more sophisticated darkroom in general to print colour. Printing B?W you can start with a complete darkroom you can likely find for $100 or so
12-03-2014, 09:18 PM - 2 Likes   #3574
500C/M file update
Zeiss 80/2.8, 100ACR
12-03-2014, 10:30 PM   #3575
gofour3's Avatar
500C/M file update
Nice, just available lighting or did you use any kind of flash?
Phil.
12-03-2014, 10:31 PM   #3576
I doubt she's involved in smoothing up pics of making them look better
I should have better qualified my statement. The default automatic settings for most minilab scanners apply both sharpening and smoothing as well as boost to saturation. If I remember I can go back through my files and PM you an example of a minilab scan done on a high-end Fujitsu running in auto-pilot mode where the artifact makes it almost impossible to work with the scan.
12-03-2014, 10:50 PM   #3577
QuoteOriginally posted by gofour3 Quote
Phil.
Thanks. Available light. I just opened the lens up all the way and shot one at 1/30th and 1/60th which was about as slow as willing to go. Those frames turned out a little thin but scannable.
12-04-2014, 05:45 AM   #3578
Don't think I posted these? Apologies if they're reposts.
Z-1P, DA35/2.4 (bar the last one), TMax 400, Canon FS4000 scans.
url=https://flic.kr/p/pvZyzW]tmax10[/url] by Rob_1234, on Flickr
f/5.6
1/1000th @ f/2.4
1/15th @ f/2.4
M50/1.4
1/500th @ f/1.4
12-04-2014, 10:34 PM - 4 Likes   #3579
Safeco Field, 500C/M, 80/2.8, 100TMX
12-05-2014, 05:31 AM   #3580
IHS
IHS's Avatar
^^^HAHAHA!!! I love that..."Thanks for spilling your beer on me you jerk!"
12-05-2014, 09:49 AM   #3581
Adding to the bw shots
https://www.flickr.com/photos/rjhooker/9294709469/
Pentax K1000
SMC Pentax-M 50mm f2
Kodak BW400cn
12-05-2014, 10:05 AM   #3582
Senior Moderator
Parallax's Avatar
https://www.pentaxforums.com/forums/12-post-your-photos/6-how-upload-photos-b...tart-here.html
12-05-2014, 10:52 AM   #3583
gofour3's Avatar
Lions Gate Bridge (P67ii & 165/4, Tri-x 400 red & polarizer filters)
Phil.
12-05-2014, 01:05 PM   #3584
hah. Thanks!
12-05-2014, 06:56 PM   #3585
45 Mike's Avatar
Taken with paper negative, Ilford RC #3, 1/4 sec f:8. I shot this with my Grafex 4x5 through a double pane window, focused on the hillside (inset). I used my new Schneider Symmar 135/235 convertible.
scanned @800dpi flatbed
I was not expecting great resolution shooting through two panes of glass. I was actually more interested in the focal length effects of swapping the cells between the 100/175 and the 135/235.
This is 100% crop of inset.
The cell swap experiment was fairly unspectacular. No discernible advantage to swapping cells from one lens set to the other.
One swap gave me about 115mm and the other swap gave me close to 120mm.
On 4x5 the difference would be like changing from a 30mm to a 31mm on a 135 camera.
autofocus, camera, d-76, dog, doubt, exposure, film, flickr, fp4, kiev, leak, lens, love, mine, minutes, nikkormat, pentax, phil, photography, pm, post, quality, roll, shot, shots, smc, sp500, station, steve, thanks
Travel Some B&W film shots from the Gulf of Gaeta, Italy Rense Post Your Photos! 3 04-23-2011 12:22 AM
First post - few b&w shots sealisthenewbeaver Photo Critique 2 09-22-2008 06:40 PM
My Pentax shots in print & film. blwnhr Photographic Technique 5 03-18-2008 05:13 PM
First shots with a zx-5 film camera (c&c welcome) jbrowning Post Your Photos! 2 12-23-2007 08:18 AM
All times are GMT -7. The time now is 04:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
