Originally posted by gofour3 Thanks guys!
I also debated about getting the 6x7 35/4.5 or the 45/4. The 35/4.5 won because it has the widest the FL and built-in filters. I did not want to have to buy a new set of b&w filters in 82mm.
Phil.
Yeah, getting colored and thick density ND filters in 82mm isn't easy. The 75mm/4.5 is also 82mm. I don't know why the lens designers didn't try harder to standardize a filter size. I typically carry 3 lenses when I go out for general shooting. A wide, normal and mild telephoto. That could be the 45mm 90 or 105mm and a 165mm (which was a LS lens in my case prior to getting the f2.8 not long ago). That would be 3 filter sizes. 82, 77 and 67mm. So often the 45mm stays at home and I take the 55mm just to eliminate that 82mm filter size
Stepper rings suck when you want to use lens hoods which I do. My Hassy system is more reasonable in that regard. They made all their lenses one filter size except for the extreme ends of the lens lineup (eg really wide and really long).
