01-31-2015, 07:34 AM - 2 Likes   #3706
Jonathan Mac's Avatar
I started "scanning" my B&W negatives last year with my K200D instead of my Epson V500 as I found it produced much higher resolution scans. Now I've got a K3 and it's even better for this purpose - the far superior AF makes things easier but the biggest difference is the K3's user modes. I set up the U3 mode to shoot in M mode at ISO 100, RAW, with a negative image in B&W. This way the jpeg straight from the camera gives me a much better idea of how the photo will come out. Especially with exposure as judging correct exposure by seeing a negative image is tough.
With a little cropping or more careful framing I could even use the straight-out-of-camera jpegs. It's a great step forward for using a DSLR for this purpose.
Here are my first few results - I used Agfa APX 100 film in a P30N while I was on holiday in Germany last summer. I've got quite a build-up of B&W negatives to scan.
IMGP0881a
by Jonathan_in_Madrid, on Flickr
IMGP0885a
IMGP0893a
IMGP0921a
IMGP0919a
01-31-2015, 08:24 AM   #3707
QuoteOriginally posted by Jonathan Mac Quote
The new camera scans are looking really good.
01-31-2015, 09:51 AM   #3708
gofour3's Avatar
IMGP0881a
IMGP0885a
IMGP0893a
IMGP0921a
IMGP0919a
+1 nice work!
Phil.
01-31-2015, 01:42 PM   #3709
hooverfocus's Avatar
IMGP0881a
IMGP0885a
IMGP0893a
IMGP0921a
IMGP0919a
#3, I think I've sat in the same spot 5 years ago
02-01-2015, 05:54 PM   #3710
Cuthbert's Avatar
Nikon F2AS, Neopan 400:
Not happy about the development, it's quite grainy.
02-02-2015, 12:13 AM   #3711
Itīs been a while since I last posted here. Here are some photos from a recent trip. All with Me super and pentax A50mm 17. lens.
Tri-x 400 @ 1600, developed in Rodinal 1:100, semi stand for 60 minutes. 10 inversions at the beginning and around 30 min.
Some of them came a bit dusty at the scanning but I donīt mind.
02-02-2015, 02:13 AM   #3712
A few more fairly abstract shots from Germany:
IMGP0952a
IMGP0963a
IMGP0965a
02-02-2015, 04:05 AM   #3713
IMGP0881a
IMGP0885a
IMGP0893a
IMGP0921a
IMGP0919a
Very good detail and clarity on these shots! How do you "scan" with your K-3? Do you have some kind of negative holder? What kind of macro lens are you using?
02-02-2015, 05:18 AM   #3714
Cuthbert's Avatar
02-02-2015, 05:52 AM   #3715
Fairy Tulle
Hello,
Here's my B&W shot!
PENTAX K-30  Photo
02-02-2015, 07:41 AM   #3716
bobbotron's Avatar
Hi Jonathan,
Can you take some photos of your K3 "scanner" setup? I'd like to try this at some point!
02-03-2015, 01:31 AM   #3717
QuoteOriginally posted by _quicksilver_ Quote
QuoteOriginally posted by bobbotron Quote
Hi Jonathan,
I should have taken a photo the other day when I had it all set up, now that I have two DSLRs. I have some ideas for improvements but this is a question of finding the time to build the necessary equipment.
Basically, I take a photo of the negative using my K3 with DA 35mm limited macro lens. The negative is in a Lomography Digitaliza to keep it flat and the Digitaliza goes into a cut-up shoebox to keep it vertical. The K3 is on a tripod (obviously) and on the other side of the negative is a remotely fired flash pointing straight at the negative and camera, and several layers of translucent plastic to act as a diffuser.
02-03-2015, 08:07 PM   #3718
bobbotron's Avatar
An old city complex near my place is being demolished, took some photos with Ilford 3200.
02-04-2015, 06:33 AM   #3719
Cuthbert's Avatar
Leica M3, Summicron DR, Elmarit 90mm and Neopan C-41:
02-04-2015, 02:06 PM   #3720
K1000, Voigtlander Color Skopar 20mm 3.5 SL II, Ilford Delta 3200
autofocus, camera, d-76, dog, doubt, exposure, film, flickr, fp4, kiev, leak, lens, love, mine, minutes, nikkormat, pentax, phil, photography, pm, post, quality, roll, shot, shots, smc, sp500, station, steve, thanks
Travel Some B&W film shots from the Gulf of Gaeta, Italy Rense Post Your Photos! 3 04-23-2011 12:22 AM
First post - few b&w shots sealisthenewbeaver Photo Critique 2 09-22-2008 06:40 PM
My Pentax shots in print & film. blwnhr Photographic Technique 5 03-18-2008 05:13 PM
First shots with a zx-5 film camera (c&c welcome) jbrowning Post Your Photos! 2 12-23-2007 08:18 AM
All times are GMT -7. The time now is 05:36 PM. | See also: NikonForums.com, part of our network of photo forums!
