08-07-2015, 01:38 AM   #4111
Cuthbert's Avatar
QuoteOriginally posted by TheLens Quote
Here are some on my Houston bike trails trip with the Spotmatic II, Takumar 50 1.4 and Ilford FP4.
---------- Post added 08-06-15 at 10:29 PM ----------
Nice bike pics Cuthbert. I really like the Yamaha 750-3.
So in the end the Spottie mkII didn't self destroy in the bike ride as you feared?
Nice pics, did you also use a yellow filter? For my pics I am kind of disappointed because XP2 always gives me a watered down look, I used a YG filter, it did help some contrast but still with a lot of light it seems the film can't handle highlights well, still I'm missing the BW400CN.
08-07-2015, 10:05 AM   #4112
TheLens's Avatar
QuoteOriginally posted by Cuthbert Quote
Yes I forgot to mention I used a #15 deep yellow filter to darken the blue sky.
08-07-2015, 04:20 PM   #4113
Cuthbert's Avatar
I've got the shots taken with my "new" Nikkormat FT3 and the F2A out of Ilfordlab, unfortunately even with a yellow filter I didn't get a nice sky like in your shots:
Still some shots are nice IMO, for instance bokeh test with Nikkor 50mm f2:
Not impressed, the bokeh is harsh even if the definition in DOF is very good.
These two are taken with the nice (and heavy) 300mm f4 IF, the bokeh is much better, not as good as the 85mm but not too bad.
Unfortunately the camera has a light leak when exposed at direct sunlight (and I don't have a case) but still I like this shot.
Same problem for this selfie with the 24mm f2.8,
This is the sharpness of the Nikkor zoom 35-200 AIs wide open (it was a competitor of the Pentax 35-210mm I wrote a review about), I shot at 200 mm not to disturb the painter.
50mm wide open.
Stepped down.
These are the shots of the FT3, later I'll post some of the F2, I hope you like them.
Film: HP5+ (and I think it's evident from the grain).
08-08-2015, 10:29 PM   #4114
TheLens's Avatar
Cuthbert, I use a #15 deep yellow filter. It does a better job on the sky that the typical #8 yellow. And it only absorbs about an additional 1/3-1/2 stop more light than the #8. I really like what a #25 red does to a blue sky, but it absorbs so much light, severely darkens green foliage, and some cameras won't meter properly with the red.
08-10-2015, 08:17 AM   #4115
I took a Fuji GSW690III out for a test drive. I shot a roll of 400TMY (at EI100) and 100ACR (shot normally) then developed them in the same tank with the same development time.
400TMY
100ACR
08-10-2015, 08:35 AM   #4116
gofour3's Avatar
I took a Fuji GSW6900III out for a test drive. I shot a roll of 400TMY (at EI100) and 100ACR (shot normally) then developed them in the same tank with the same development time.
400TMY
100ACR
Very nice. Haven't seen any of your shots in awhile, we missed you!
Phil.
08-10-2015, 09:07 AM - 3 Likes   #4117
QuoteOriginally posted by gofour3 Quote
Phil.
Thanks, Phil. I've been shooting digital for other people. It's not very fun. But with that behind me I do look forward to taking pictures for myself and more BW film work.
---------- Post added 08-10-15 at 09:21 ----------
Set up some shots to test 400TMY and 100ACR in the same tank with sheet film too.
400TMY
100ACR.
That crooked chemical bottle bugs me to no end. I guess the tile was not flat on that spot.
08-10-2015, 12:40 PM - 2 Likes   #4118
K1000
SMC 50mm F1.2
Fomapan 200
08-10-2015, 09:03 PM - 1 Like   #4119
bobbotron's Avatar
SFX 200 w/ DD-X, some photos from Canadian Parliament buildings.
Helios lens, maybe with a R72 filter
08-11-2015, 12:15 AM   #4120
Jonathan Mac's Avatar
400TMY
100ACR
Good to know this can be done - the results look very very similar to the Acros, maybe darker in the shadows. I've tried TMY400 at 200 but not at 100. It's the easiest and cheapest B&W film for me to get here (in the guise of Lomo Lady Grey.
08-11-2015, 05:27 AM   #4121
QuoteOriginally posted by Jonathan Mac Quote
Good to know this can be done - the results look very very similar to the Acros, maybe darker in the shadows. I've tried TMY400 at 200 but not at 100. .
Did you decrease the development time when you shot TMY at EI200? I also shoot TMY at EI50. I cut its normal dev time in half when I shoot it at that exposure index. That's why I can mix the two. It just so happens the time for TMY at EI100 is close enough to 100ACR's normal time I can mix them. I do that to get more dynamic range from the film.
So come to think of it, I shoot TMY at EI50, 100, 400 and 800. It is a very speed flexible film.
08-11-2015, 07:00 PM - 5 Likes   #4122
g026r's Avatar
Pentax K2.
smc Pentax-A 50mm f1.4.
Rollei Retro 80S.
08-12-2015, 01:06 AM   #4123
Yes, I'm sure I adjusted it, can't tell you by how much off the top of my head, but it would have been done by the book (the Ilfosol instructions).
08-12-2015, 07:30 AM   #4124
Okay. I think most developers you can go a stop over exposing and under developing. Much more than that then it becomes developer dependent especially if a developer has a minimum required time.
I shoot TMY so much is mostly out of necessity. I can't use the glass negative carrier for my 120 roll film scanner anymore because it is too scratched up from years of cleaning the surface and it shows in the scans and a new one is not made anymore. Now, I have to use the crappy sock one and does not hold film that is thin or curly well at all.
TMY is among the thickest I've used and it will lay pretty flat. I even have a hard time with Acros now and I use to shoot that film a lot. I think someone needs to make a 120 roll film scanner with a round drum for a negative carrier instead of a flat plane. Film likes to wrap around a large diameter drum way better than lay flat.
08-12-2015, 08:05 AM - 1 Like   #4125
Cuthbert's Avatar
Girl smoking a cigarette outside a church in Oxford:
Canon F-1n, FD 35mm f2.0 Chrome nose, BW400CN and YG filter.
autofocus, camera, d-76, dog, doubt, exposure, film, flickr, fp4, kiev, leak, lens, love, mine, minutes, nikkormat, pentax, phil, photography, pm, post, quality, roll, shot, shots, smc, sp500, station, steve, thanks
Travel Some B&W film shots from the Gulf of Gaeta, Italy Rense Post Your Photos! 3 04-23-2011 12:22 AM
First post - few b&w shots sealisthenewbeaver Photo Critique 2 09-22-2008 06:40 PM
My Pentax shots in print & film. blwnhr Photographic Technique 5 03-18-2008 05:13 PM
First shots with a zx-5 film camera (c&c welcome) jbrowning Post Your Photos! 2 12-23-2007 08:18 AM
All times are GMT -7. The time now is 03:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
