01-28-2016, 07:54 PM - 1 Like   #4636
Jacquot's Avatar
QuoteOriginally posted by Swift1 Quote
Here's my first ever large format photo. The film was home developed by a friend, and there was some uneven developing so I added a vignette.
Pacemaker Speed Graphic
Kodak Ektar 127/4.7
Fomapan 100
Congratulations, and great detail on that amazing tree. I love trees. Good luck working in large format!
David
01-28-2016, 10:27 PM   #4637
I forget, what do you use for a daylight tank.
It's a HP Combi tank shown in this photo on the right. I have a couple of them and use them because they adapted to Ag-O-Matic nicely.
Wisner 4x5 Technical Field, Schneider Symmar-S 180/5.6, 320TXP, PMK Pyro
01-29-2016, 06:47 PM - 1 Like   #4638
45 Mike's Avatar
One from my almost new Petri 7 shootin home rolled Plus-X
---------- Post added 01-29-16 at 17:54 ----------
A few from my Pentax P3N with a 50mm A 1.7
On home rolled Kodak Plus-X
This one breaks my heart. I really liked this one, but the film scratches just ruins the affair. sigh, bummer.
I scan the negs as color, so I can sometimes do some colorization , I kinda like the subtle effect the color has here.
And a shot of a rock wall.
---------- Post added 01-29-16 at 18:00 ----------
A shot from my Petri 7, using off camera flash, of my new Minolta Hi-Matic G, which apparently does do needle capture exposure lock, I am running a roll through it and will find out for sure and certain, if it really does, or really doesn't.
01-30-2016, 04:32 AM - 1 Like   #4639
Shots from a few months ago. It was to test out using my green filter. I think it turned out pretty nice.
01-30-2016, 10:46 PM   #4640
45 Mike's Avatar
QuoteOriginally posted by 45 Mike Quote
Arrrgh. I was about to strip out the roll of Plus-X from my bulk loader and start over with a fresh roll, because of the scratches on the film, they just never went away, and it was making me angry.
I bought the loader, and the seller did not tell me it had film in it. I opened it, saw the film and closed it right away, the edges are slightly exposed, but generally it looks ok for developing.
I never used a loader before, and there are no instructions that I could find for this particular loader.
The scratches are being caused by the light trap. I had no idea that I needed to open and close that trap for every roll. I thought the locking lever opened and closed that trap.
I just watched a video that shows the Alden-74 being used properly and it shows that the trap is opened and closed on the bulk door and it needs to be done for every roll.
Now I have a fresh roll that should be unscratched, and I am gonna be soooo happy, finally.
01-31-2016, 09:14 AM   #4641
Those loader instructions sound like my bulk loader's operation. What are you using?
I get some scratches with mine too. None too serious if I recall but it has been a long time since I last used it. I think the last time was when I sent stevebrot, a member here on PF, a few rolls to try some time ago. I have it loaded with some Panatomic-X from years ago still. I've often thought the re-loadable 135 canister could also be a contributing factor to scratches. But I've never been able to say for sure.
01-31-2016, 10:31 AM   #4642
45 Mike's Avatar
An Alden 74. It came loaded, i have no idea if it is loaded correctly. Now that I am opening the light trap, the roller is much smoother and almost no drag. i think it's working great.
On this model, apparently, there is no felt in the loader, so the only surface that can cause scratches is the cartridge felt, (unless of course, i fail to "open" the light trap). That's the theory anyways.
01-31-2016, 11:45 AM   #4643
Yea, I have the same brand. I think if the developed roll is okay then you're good less any scratches of course.
01-31-2016, 03:07 PM - 1 Like   #4644
Duplo's Avatar
Finally a few hours at the desktop again
Finally got a chance to develop and scan some film again
So here are a few
Handheld long exposure during a nighttime snowfall (ME Super, 50/1.7 HP5 @ 800)
One from the Studio (67ii, 55/4, no. 1 tube, Tri-x @ 320)
From a misty morning run (Cosina CX-1 Double X)
01-31-2016, 03:47 PM - 1 Like   #4645
Otis Memorial Pentaxian
That is a shame. My Watson loader is the same. (The Alden-74 is a variant of the Watson design.) You have to remember to open the trap before rolling the film. As tuco mentioned, the other possible source of scratches would be the felt trap on the canister. It could be worse. The Lloyd-style loaders have a stationary felt trap that is notorious for scratching.
01-31-2016, 03:50 PM   #4646
A gift that was and is still very much appreciated. I made some very nice images from that donation.
01-31-2016, 10:08 PM   #4647
Did you have any scratches?
01-31-2016, 11:49 PM   #4648
45 Mike's Avatar
Yep, I have heard of dirty felt in the cartridge causing scratches, but my cartridges are brand new, never used. The scratches I was getting are all very regular and every roll was the same scratches. Not just similar, but the same. I am rather certain that now that i am opening the trap correctly, those will be gone and I will be very happy with the results. I think I have two rolls of scratchy film in cameras, and one on the shelf. I am about to scrap the one on the shelf, but I might keep it as a test roll for whatever someday.
02-01-2016, 06:55 AM   #4649
I am always worried about scratches. So far I have been lucky and maybe only had one roll with anything significant. 3M makes a roll of tape with the same sticky back as a post it note. I use that to clean the felt on the cartridges. I also built my own loader that I have to use in the dark. I load the film on the reel and then slide it into the cartridge so it only passes the felt once. Like I said so far so good.
When loading your film how do you attach it to the reel? I have used tape but I often get residue on areas I do not want. I have been trying to work out a way to make some sort of punch that would cut the shape and put a hole in the end like they do at the factory. I have a way but I have yet to get something simple and easy.
I have been having trouble linking photos from the new google pictures, has anyone else had trouble with it?
02-01-2016, 01:22 PM - 2 Likes   #4650
K1000, M50/1.7, TMax 400
autofocus, camera, d-76, dog, doubt, exposure, film, flickr, fp4, kiev, leak, lens, love, mine, minutes, nikkormat, pentax, phil, photography, pm, post, quality, roll, shot, shots, smc, sp500, station, steve, thanks
58mm Lens Club - Bring your Biotar, your Helios, your Tak 58mm... bring 'em all! pepperberry farm Lens Clubs 307 3 Days Ago 07:57 AM
Post-Processing The Film Emulation Challenge - Post your Digital Pictures with that Film look ChristianRock Mini-Challenges, Games, and Photo Stories 22 07-14-2023 10:20 AM
I'd Print and Hang This - Your Best Film Shots Eyewanders Film SLRs and Compact Film Cameras 102 01-09-2020 01:36 PM
Old tech shootout: your MX-1 vs your phone. Is your MX-1 still holding it's own? MD Optofonik Pentax Compact Cameras 7 05-16-2019 07:40 PM
Photo Story Time documents: Show me your genre study, your reportage, your photo story... etc. christophleipzig Mini-Challenges, Games, and Photo Stories 11 10-15-2011 06:26 AM
All times are GMT -7. The time now is 01:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
