Your welcome.
What camera(s) gave you the problems.
I use the Hyper Program mode a lot with my PZ-1. What i like to do, and YMMV, is set a shutter and Ap speed to what i think the scene would best be, say for argument, 1/125 at F4.
I focus and compose, then look to the right in the finder, you'll see your setting. If your set up for TV and the metering does not like what you have set, adjust the TV, or Av till the blink stops. If it does not give you the DOF or shutter speed you are looking for, just adjust until your happy.
There is also a split metering circle that shows under or over exposed as well, i just remembered that.
Not sure if i am explaining that correctly.
Its a great system. I did not own a Dl, but i think only the istD had the Hyper mode.??. The K10D does.
My PZ-1 had a FA Power Zoom 28-105 on it as the walk around lens for 3-4 years. Good combo.
Dave
Reason: Forgot a question
