12-07-2007, 09:53 PM   #1
konraDarnok's Avatar
Old School, I need your help!
I'm scanning some negatives from 1976. What is this rainbow distortion thru the horizontal center of the photo? It looks much worse at full resolution. It doesn't appear on all the negatives. Has anyone seen anything like this?
I'm scanning with an Epson V500.
12-07-2007, 09:54 PM   #2
Could it be moire?
12-07-2007, 10:01 PM   #3
-=JoN=-'s Avatar
could just be that the negative may have degraded somewhat..it is what...32 years old....
could just be some warping on the negative
could be something on the negative too..
clean it?
12-07-2007, 10:05 PM   #4
FotoPete's Avatar
YEa, if its a gloss print, it's probably distortions/reflections from gloss to scanner glass to gloss, etc.
12-07-2007, 11:15 PM   #5
That is a weird one! Make sure the glass is sparkling clean and lint free. But it may be a software issue. Try reinstalling your scanner software, see it that does the trick. Or try "Vuescan"; I find it works better than the provided software from Epson.
12-08-2007, 06:19 AM   #6
I remember a Similar problem some one had on another list, years ago. It turned out the neg's were touching the glass, using a flatbed scanner with the plastic film holders that sat on the glass. Negs were slightly bent and touched part of the glass. I believe it was an Epson 2400 or around that vintage.,
Just a thought
Dave
12-08-2007, 06:30 AM   #7
-=JoN=-'s Avatar
hm...if it's not a true negative scanner, and just a flatbed w/ the adapder...I would agree w/ pentkon......1 reason why I bought an actual film scanner back then
12-08-2007, 06:40 AM   #8
Nesster's Avatar
Yep, to me it looks like the neg is touching scanner glass, causing newton rings.
Flatten the negatives and this should go away
12-08-2007, 07:11 AM   #9
Yep. Newton Rings. They go away if I scan with the emulsion side down, as the negative is now slightly curved away from the glass rather than towards it -- hence preventing the negative from touching the glass.
Learn something new every day. Thank you for the replies.
negatives
No Weapons in school graphicgr8s General Talk 13 06-20-2010 09:57 PM
Landscape Old School ramseybuckeye Post Your Photos! 6 11-02-2009 07:25 PM
I tried new school... and decided on old school dugrant153 Photographic Technique 16 11-10-2008 10:03 PM
Photos Taken at School tux08902 Post Your Photos! 5 03-07-2008 09:06 PM
I need help for school... plmuzikmaster Photographic Technique 29 02-15-2007 04:40 PM
All times are GMT -7. The time now is 07:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
