Originally posted by billypip Thank you all for the helpful tips. I look forward to going out and shooting with these films and if all goes well i might shoot film as well as digital. There are a couple of points im not sure of however......,rwe0112 you say you have pushed it to 800 , as a beginner im not sure what this means and titrisol........do you mean use the eraser in the film compartment and if so, what does this do ? Forgive my ignorance .
1) Pushing a film:- This means underexposing the film with the view to making the shutter speed fast enough to hand hold in poor light. So you take your 100 iso film, put it in your camera and set the iso dial to 800. This is called a 3 stop push. The camera thinks you have 800 iso film and sets the shutter speed 3 stops faster than it really should be.
However, when you have shot your film, it will be 3 stops underexposed (very dark) so you have to compensate for this by overdeveloping the film the equivalent of 3 stops. This is easy if you are developing your own film but if you are giving it to a lab for developing, you must tell them that the film was pushed 3 stops. They may charge more for this.
2) You use the eraser on the end of a pencil on the battery terminals of the camera. It is very good for cleaning them up.
P.S. B&W is great for street photography so you might want to give that a go. You might not even have to push the film at all if the light is good. If you get round to buying some more film, try 400 ISO film like Kodak Tmax 400 or Kodak Tri-X. Its a lot more suited to what you are trying to do. 7dayshop are usually the cheapest in the UK.
