02-15-2012, 05:34 PM   #1
Spotmatic 2 mirror cleaning - any advice? SUCCESS
Hello,
My mirror felt shock absorber has turned to jam and is stuck lots of goo to the mirror.
I know it is sensitive but I would like to know who has tried to clean their mirror and did it end in disaster or can it be done carefully.
I have the nice new seals from Jon Goodman but before I install them I would like to attach that mirror.
Note that am fairly comfortable with technical jobs, lens and shutter repairs etc etc.
Best regards
Brett
02-15-2012, 10:36 PM   #2
My standard answer is to leave that sort of cleaning to the pros. The mirror surface is very fragile by nature and may be even more so with age. Every scratch degrades the image in the viewfinder. I would see if a local camera repair can swab the mirror clean for you.
02-18-2012, 07:02 PM   #3
bmf
Update- SUCCESS
Thanks for the advice Steve but I was hard headed and went with Jon Goodmans steps and attacked the mirror with alcohol and pec pads letting the alcohol do the work and the pec pads do the very gentle lifting after a few minutes of soaking- it worked famously. My mirror is now sparkling. I replaced all the light seals and the camera shock absorbing foam at the same time (thanks Jon) and my Spotmatic II now looks good as new!
Now for some photography!!
Brett
02-18-2012, 08:57 PM   #4
Glad you found a low-cost solution! If Jon Goodman says this is how it is done, then that is good enough for me! Jon is a great guy and knows what he is talking about.
02-18-2012, 09:13 PM   #5
paulh's Avatar
Glad I found this thread! I'm in the same exact situation (Spot II, rotten foam, dirty mirror, seal kit coming from Jon) I'll be giving it a try myself soon. Thanks for passing on the info!
02-19-2012, 01:09 AM   #6
rayallen's Avatar
Location: Forresters Beach, Central Coast, NSW, Australia
Jon Goodman to the rescue again. Top guy.
mirror
Sensor/Mirror Cleaning godavari Pentax K-5 17 12-01-2011 11:55 AM
Mirror Cleaning Kx-Rick Troubleshooting and Beginner Help 3 08-09-2011 04:20 AM
Cleaning Mirror , Viewfinder MIKESDEALS Pentax Film SLR Discussion 4 02-03-2011 03:53 PM
Mirror lens cleaning Eruditass Pentax SLR Lens Discussion 5 08-20-2010 08:42 PM
Smudge mark on mirror cleaning? iht Pentax DSLR Discussion 3 07-13-2010 03:25 PM
All times are GMT -7. The time now is 11:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
