02-17-2012, 10:49 AM   #1
aurele's Avatar
Long exposure / provia 200 : how to know the good exposure compensation ?
Hello everyone !
I just bought some Fuji Superia 200, for the week end, and i wanted to try my first long exposure with film.
But i'm not sūre to understand how to calculate the compensation i need to apply
Here is what Fuji said about the long exposure compensation :
"No exposure or color balance compensation is required
for exposures within a 1/4000 to 2 second shutter
speed range. However, for exposures of 4 seconds or
longer, provide the compensations indicated below.
Exposure Time (sec) | 1/400 - 2 | 4 | 16 | 64 |
Exposure Corrections* | unnecessary | +1/3 | +2/3 | +1 |
* "+" followed by number = required increase in lens opening.
Except for special effects, the normal intensity ratio for
main-to-fill subject lighting should remain within 1:4
limits.
So if, according to my meter, i should expose say 128 sec, i should in reality expose 512 sec ?
thanks a lot to anyone who can help me
02-17-2012, 11:08 AM   #2
Swift1's Avatar
According to this, http://www.fujifilmusa.com/shared/bin/ProfessionalFilmDataGuide.pdf anything past 64 seconds metered require +1 stop exposure. So for a meter reading of 128s, you should expose for 256s.
02-17-2012, 03:45 PM   #3
Alliecat's Avatar
I use Superia 200; print film is pretty forgiving with exposure times. When doing night shots, which are usually less than a minute in fairly well-lit harbours, I usually add half a stop to everything. If it's particularly dark I might add a whole stop.
If you have a scanner you can always tweak a little bit to do reprints. Or, if you have them printed at a lab, you could ask them to print a little lighter or darker to adjust the prints.
Bonne chance
02-18-2012, 06:58 PM   #4
Superia 200 does pretty well in long exposures. You can either expose one stop longer, as recommended above or you might consider opening the aperture a stop instead if the longer time introduces problems (motion, etc).
If we follow the compensation pattern you would add 1/3 stop for every quadrupling of exposure time from 4 seconds on. For 128 seconds I would expose 1 1/3 stops over or about 340 seconds.
2 4 16 64 256 1024 4096 Metered Exposure
2 6 27 128 681 3400 16384 Compensated Exposure
0 1/3 2/3 1 1 1/3 1 2/3 2 F-Stop Increase in Exposure
I'm not sure how linear this continues beyond 64 seconds, but this is a good starting point. As with using any new film, test for your conditions and take good notes!
compensation, exposure, exposure compensation, exposures, fuji, sec
exposure compensation k10d vimeto Troubleshooting and Beginner Help 19 04-13-2014 08:07 PM
Camera exposure compensation vs flash compensation raider Photographic Technique 4 09-29-2011 05:02 PM
Exposure Compensation for a manual lens Vantage-Point Pentax SLR Lens Discussion 7 08-05-2011 07:04 PM
using the exposure compensation tinabalagosa Troubleshooting and Beginner Help 5 04-25-2010 01:55 PM
Exposure compensation in P67ii Jerry_K Pentax Medium Format 20 04-14-2010 06:21 AM
All times are GMT -7. The time now is 07:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
