Originally posted by kcobain1992 I have to say first that the rewind shaft of the SP is different from the SPII, the latter being taller than the former. They are compatible though, if you don't mind the difference in height (assuming you have an SPII or SPF replacement). Now what I usually do to reinsert the shaft: there's a catch in there that's keeping the shaft from being completely inserted. From the camera top, insert a needle in the rewind hole and push the catch sideways while simultaneously pushing the shaft upwards from the bottom. It should take a couple of minutes of fiddling, but it should work.
you were correct, and I got it pretty much right away with a tiny safety pin. thanks, both of you!
