Originally posted by monochrome what I have in my Spotmatic right now is a Maxell SR44W Silver Oxide. I specifically asked Eric Hendrickson wether a 1.55v battery in a Spotmatic SP would affect the meter, but I didn't get a clear answer. he stated that he could adjust the metering, but I actually do not know if it was or wasn't adjusted on mine when he CLA'd it. I have also been told on many occasions that even the original SP is in fact not affected by a higher voltage battery. I have a CRIS adapter as well that can reduce the voltage of a 1.55v battery down to 1.35v. when I use that and a Maxell SR626SW silver oxide, also at 1.55v, I notice no difference in the metering. therefore my conclusion is at either 1.5 or 1.3v my meter registers no difference. both are maxell and both are silver oxide cells. if all of these are also 1.55v silver oxide cells, I do not see any reason why any of the above listed will not work and give accurate readings in a Spotmatic meter.
so my personal recommendation is if you are planning on letting Eric CLA it. request to have the meter adjusted to 1.55v, won't cost extra as far as I know, but in my experience a 1.55v or a 1.35v will not make a difference in a spotmatic's meter. and only use silver oxide cells, if you can. alkaline cells don't have a linear discharge curve and this will affect your meter reading as the battery nears the end of its life. they also do not last as long as silver oxide cells for camera meters. any brand of silver oxide cell is ok, I don't know of any brand that outright won't work if it is a 357/SR/LR44 type button cell.
