02-29-2012, 01:35 AM   #1
P30 help!!!!
Hey guys
I have recently decided to try a bit of film photography with my grandads P30. Ive got some 400 speed film which i thought would be ok to use in daylight situations, but every time i go out to shoot it gives me an overexposed reading. Ive tried usung both the Program mode on some of the lenses i have and also shooting at f/32 at 1000/1 but i still get an overexposed reading. Is there some way i can change the iso within the camera, ive read the manual but it doesn't seem to help.
Any advise would be great
Thanks
Jake
02-29-2012, 01:55 AM   #2
ihasa's Avatar
There is no way to set the ISO on the camera. It detects the DX code on the film cannister. The only way of over-riding would be to buy a replacement DX code label and stick it over the original one...
If there's no DX code on the film, the camera defaults to ISO100 or something I think.
Sounds like the meter may not be working... What happens in manual mode?
02-29-2012, 02:07 AM   #3
Manual mode is the exact same and i am using Fujifilm 400 speed X-tra Superior film which i am pretty sure is DX coded film. Is there anyway i could maybe check if the meter is broken?
02-29-2012, 06:35 AM   #4
manacho2005's Avatar
Use your dof preview to see if the lens is stopping down. You may be shooting wide open the whole time. My P3 stuck once, but nothing a drop of oil didn't fix.
02-29-2012, 07:30 AM   #5
womble's Avatar
Unless you are somewhere extremely bright and sunny you shouldn't be getting those sorts of speeds. Sounds like the camera may need a service.
K.
02-29-2012, 07:32 AM   #6
EyeSpy's Avatar
you might need new batteries.
02-29-2012, 07:42 AM   #7
Banned
if you are shooting at f32 and 1/1000 of a sec and still getting overexposure, then clearly something isn't working correctly. in bright daylight with 400 speed film, 1/1000 of a second should need somewhere between f5,6 or f8 at about EV 15 and around f/11 or f16 at around EV 18, without any sort of ND filter for reducing incoming light. I don't know exactly how the P30 operates, but I certainly assume it does open aperture metering, since it uses A series lenses. by the way, what lens are you using? if its giving you these kind of readings, its unlikely to be a mechanical problem with the lens. either the camera isn't reading the aperture correctly from the lens data contacts (assuming you are using an A series lens) the camera isn't coupling correctly with the aperture coupling (assuming you are using a non-A lens) can the P30 do open aperture metering with non-A lenses? or the meter itself is malfunctioning. any of which, I think will need some sort of professional servicing to get fixed.
film, p30, reading
For Sale - Sold: Cheap P30 body with case bdery Sold Items 4 01-18-2012 06:01 AM
P3/P30 focusing screen removal GmcarsMAN Film SLRs and Compact Film Cameras 2 12-04-2011 09:10 AM
Green P30 body ChrisPlatt Film SLRs and Compact Film Cameras 2 06-23-2011 03:46 PM
pentax p30 tomb2112 Film SLRs and Compact Film Cameras 12 02-23-2011 08:34 PM
K-7 / fz-20 / p30 hcc Pentax DSLR Discussion 3 08-31-2010 02:28 PM
All times are GMT -7. The time now is 10:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
