03-27-2012, 02:02 AM   #1
sunny16's Avatar
Spotmatic F repair question
So I bought a black Spotmatic F on ebay. It is in really clean, nice looking condition (looks like it was hardly used.) The only thing is the lightmeter doesn't work. I have a working chrome Spotmatic F and used the same battery to test in the new one. Needle just stays in the center. Battery compartment is clean and the metal connector in the compartment has a good spring to it, so that shouldn't be the problem.
I know that no one can answer 100%, but would this be something that might be able to be repaired? Specifically if I sent it out to Eric?
I just don't know if it is even reasonable to expect that this is something that might be fixed. Any feedback is appreciated. Thanks!
03-27-2012, 02:05 AM   #2
maltfalc's Avatar
mine has the same problem.
03-27-2012, 02:56 AM   #3
Giveaway winner!
MysteryOnion's Avatar
I have a Spot-F that has a nonworking meter as well, I directly tested the meter with a little voltage and it did not move. It seems that the coil spring inside has broken away from the post it is attached to and that means not voltage to charge a coil and move it around the magnet inside. I've had this problem with a KX and know its lightmeter stopped due being dropped, but shows no dents because it was in a bag or something (seller mentioned). I've since repaired the KX and hope to do the same job on the Spotmatic soon, but it is not an easy soldering job due to the size. The common repair when you send it out is that the entire meter unit (the part with the needle in it) is replaced and I've recently heard from a different post that Eric was running low on those units? You should check with him soon about that and send in for repairs.
03-27-2012, 04:53 AM   #4
monochrome's Avatar
As you know, your money risk when you send something to Eric for evaluation is limited to the postage to Sharps Chapel, TN. If you decline his estimate he'll send the camera back to you at no cost to you. His estimates are free
battery, compartment, spotmatic
K-X Repair Question csbtrod Troubleshooting and Beginner Help 2 02-19-2012 01:34 PM
K7 Out of warranty repair question Ed n Georgia Pentax DSLR Discussion 6 02-04-2011 11:25 AM
Spotmatic; shutter question JQP Pentax Film SLR Discussion 4 06-23-2010 04:22 AM
Spotmatic II Iso question Wenders Pentax Film SLR Discussion 3 06-15-2010 02:39 PM
All times are GMT -7. The time now is 07:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
