Can someone please confirm that this camera expose correctly with A, F, FA or DFA lenses when the aperture is set on A.
Someone is saying and i quote.
Quote: Your camera has a lens mount called a "crippled KAF mount." This means you need SMC Pentax FAJ lenses. It will work with non-FAJ lenses if (1) the lens in question has an "A" setting, and (2) the "A" setting is engaged; however, a non-FAJ lens will only work in AV and M modes. You really want the FAJ lenses, that will work in all modes.
i say
Quote: 1) is correct but 2) isn't
The only difference between FA and FAJ is that FA has an aperture ring so it works on older cameras as well, FAJ does not have an aperture ring so it's always in Auto aperture so you need a camera that support that.
If you put A, F, FA or DFA in Auto aperture it will function precisely the same as an FAJ lens so there is no advantage into only buying or looking for FAJ lens, it does not give you anything extra. And yes i'm 100% sure these lenses work in Tv mode if set on auto aperture.
he
Quote: If you read the overview and the rest of the page in that second link, it says the same thing I said in (2), that the A setting has to be engaged. It also says that her camera will underexpose by two stops if a non-FAJ lens does not have a fixed aperture.
So can someone please that have actually used a MZ-50/ZX-50 help me out.
