Originally posted by chrish I have a ZX-L and use my flash on auto mode for fill. I set my SB-28 to auto, and then set it to one or two stops less than what I'm shooting.
E.g., If I was shooting 400asa film at f8 I'd set the speedlight to iso 400, A mode, and f4 then fire away. A mode will work either direct or bouncing off a wall/ceiling.
So, I ran a roll of test film thru my PZ1-p using the internal flash and shooting the same scenes with natural light, flash w/no compensation, -1 and -1.66. I ended up prefering the plain old TTL flash with no compensation for MOST of the pics. I'm really pleased with the way Pentax has programmed their flash on this camera. I also shot the same scenes side by side with my Nikon F4 and an SB-800 flash. The Nikon tended more towards a "flashy" look rather than a natural look. Different, not better or worse depending on what you want to achieve. The Nikon shots have a harder light to the subject looking a little bit more glamour like and the Pentax ones have the flash more subdued as related to the scene exposure.
Having said that, the popup on my PZ1-p BROKE after two days of owning the camera. I had to remove the top of the flash, drill out an area and epoxy the spring back in place. The plastic on this camera is very brittle...not sure how long it will last which may explain why you hardly ever see these around.
