05-06-2012, 12:33 PM   #1
Rewinding problem on K-1000
My wife used my camera and attempted to rewind the camera without pushing the rewind button for a few minutes. She was not aware of the button nor how the rewind mechanism should feel. Now there is a roll of film stuck in the camera at it's end and the rewind lever has absolutely no tension or sign of engaging the film. Instead, the lever makes a faint clicking sound when the button is depressed during rewinding. Is the rewind mechanism broken so easily or is it even broken? How do I find and solve this issue?
Thank you,
05-06-2012, 12:40 PM   #2
Most likely, it is the film that is broken.
05-06-2012, 01:16 PM   #3
Can I distinguish between a broken rewind mechanism and broken film? Can the film be retrieved to be developed ?
05-06-2012, 01:47 PM   #4
I took the chance and found that the film had simply rolled right out of the film casing. The camera seems fine.
Thanks
05-06-2012, 02:46 PM   #5
Pioneer's Avatar
Yep, happens every time. The film's attachment inside the cassette is WAYY weaker than the rewind mechanism. However I guess it is possible on some of the K1000s with a plastic fork to break the rewind fork doing that, particularly if it has become a bit brittle.
05-06-2012, 04:49 PM   #6
Simian Summit's Avatar
Probably the easiest way to know for sure is to open the camera either in a changing bag or similar dark place and check it out. If you do this, and the film is broken you can roll it by hand and pop it into a black film canister and drop it off for development. Most places can deal with this.
05-07-2012, 05:48 AM   #7
Thanks for the advice. So, just to recap, I need to ensure that I rewind the film at exposure #24 to avoid the film pulling out of its case?
05-07-2012, 08:55 AM   #8
I don't think that's necessary. On my MX I can usually pull up to about 27 frames (counting 0, and sometimes 00 if I'm lucky). I find that the advancing lever just gets stuck when your done...just don't force anything. It's always a bad sign.
05-07-2012, 01:22 PM   #9
I was not using the camera when the film ran out so I am unable to say what was felt during the last film advance. I know that I am able to feel that final advance which often does not fully cock the shutter. I have also had more than 24 pictures out of a 24 exposure film. I am glad that the camera is still functioning well though. It takes great pictures.
button, camera, film, lever, mechanism, rewind
Video problem on Optio RS 1000 theonethatsleft Troubleshooting and Beginner Help 1 09-01-2011 07:27 AM
Super Program Rewinding Problem Fiddling Bob Troubleshooting and Beginner Help 10 01-06-2011 02:59 PM
Had a K-1000 Aknot Welcomes and Introductions 3 07-29-2010 07:49 PM
Starblitz 1000 Auto Macro-Lite x-sync problem Howdy Pentax Camera and Field Accessories 0 02-22-2010 08:34 AM
Pentax LX rewinding problem Pusiek Pentax Film SLR Discussion 11 12-02-2008 04:18 PM
All times are GMT -7. The time now is 04:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
