05-15-2012, 10:50 AM   #1
red band in developed photos
Hi,
Got out my dads vintage 35mm slr and it still works pretty well execpt when the photos were developed a slight red hue verticle band is visible on one side in some of the photos. Is this light leaking into the film when it is in the camera, or is this band a result of the film processing.
Cheers
05-15-2012, 12:27 PM   #2
Nesster's Avatar
Show us a sample. It may be a leak, though very likely it is a developmen/scanning issue. Can you tell if the band is visible in the negatives?
05-15-2012, 12:46 PM   #3
kcobain1992's Avatar
I don't think you can tell whether the film has seen the light through a leak in the back or because of improper handling, except if the red bands are in the same place on all frames. Another sure sign of telling is if the camera has an ever-ready case, which acts like a shield against light and on some pictures you had it on, and on some you had it off, resulting in light leaks. Otherwise, it happened to me (my bro, actually) to open the film door while the film wasn't still fully unwound, and the result was something like this:
If you find out that the camera is on fault, then search ebay for "light seals" for your camera model.
05-17-2012, 09:50 AM   #4
Hopefully a light leak. Could also potentially be a sticky or slow curtain issue. Check the light seals first. If they're gone or gummy and just falling apart, send and email to Jon Goodman (formerly "Interslice" on eBay) at jgood21967@aol.com and ask him for a K1000 light seal kit. He still sells dozen's of light seal kits for various camera models for $10-$15 each and they always fit perfectly.
If it turns out to be a mechanical issue with the camera, you can send it to Eric at Home for CLA or repair.
band, film, photos
Abstract Light Painting band photos Wired Post Your Photos! 0 05-12-2012 12:07 AM
The red X instead of photos ... jpzk Site Suggestions and Help 9 01-24-2011 05:19 PM
People Strike Up The Band - (6th Grade Band) atupdate Post Your Photos! 4 12-12-2010 06:48 PM
Band photos... DanLoc78 Digital Processing, Software, and Printing 3 02-18-2009 08:22 AM
A few photos from a band in studio celetron Post Your Photos! 2 09-26-2008 02:52 AM
All times are GMT -7. The time now is 02:28 AM. | See also: NikonForums.com, part of our network of photo forums!
