01-24-2008, 09:55 AM   #16
Seems the various versions of the 50mm f1.2 have different #s of aperture blades. I'd think they would have different optical signitures therefore.
01-24-2008, 12:04 PM   #17
MRRiley's Avatar
to the point of the OP's question. You would need a Pentax K-to-Canon adapter. Not sure anyone even makes one, and you'd have to be careful what Canon mount, as there are at least 3 kinds. In your case, you'd most likely have to get PK-to-Canon Digital...
Ohhhh, and regardless of what version (K, A, etc) the 50mm is, it will be all manual and stop-down metering on your canon if you do manage to find an adapter.
p.s. I looked online and couldnt find a PK-to-Canon adapter. Did see a Nikon-to-Canon one for $150 so this exercise could end up costing more than just out and out buying a fast Canon lens for your DSLR.
01-24-2008, 12:29 PM   #18
amateur6's Avatar
QuoteOriginally posted by MRRiley Quote
to the point of the OP's question. You would need a Pentax K to Canon adapter. Not sure anyone even makes one, and you'd have to be careful what Canon mount, as there are at least 3 kinds. In your case, you'd have to get PK-to-Canon Digital...
(sorry, Mike, not stalking you, I swear)
Judging by what was done here (Pentax SMC Pentax 200/2.5 lens - eBay (item 110205030884 end time Dec-12-07 17:59:27 PST)) , it seems that you'll also have to cut off the aperture control lever and aperture lever shield, if this person knew what they were doing...
01-24-2008, 12:33 PM   #19
Moderator Emeritus
I think you are both right. I saw a similar 77mm Limited that was cut down the same way and the mount adapter he used was similar to the following:
Mount Adaptor for Canon EOS Body to Pentax K Lenses - eBay (item 270102955098 end time Feb-16-08 09:27:37 PST)
It seems like an expensive way to modify a lens as well as the lens might us infinity focus.
01-24-2008, 12:33 PM   #20
MRRiley's Avatar
QuoteOriginally posted by amateur6 Quote
I can't get to ebay from work, but that does sound reasonable. The lever and shield would probably impact or interfere with mounting. What an horrible end to a fine Pentax lens... being butchered so it can be mounted on a Canon... UGH!
01-24-2008, 12:36 PM   #21
MRRiley's Avatar
QuoteOriginally posted by Peter Zack Quote
Doing this to an old 50mm f1.2 is sad but to do it to a 77mm LTD should be a felony punishable by DEATH!
01-24-2008, 02:11 PM   #22
Oh no... Are you guys trying to talk me out of this It must be a conspirisy.
I'm using m42 lenses on my canon with no problems. Are you saying there would be issues with the K mount?
I have no problems with using an adapter, but if I must modify the lens... well then it's going to be up for sale here on the forum. Here's the adapter I plan on using.
Canon EOS to Pentax K PK Lens Adapter Brass NEW - eBay (item 360015505272 end time Jan-26-08 17:16:31 PST)
01-24-2008, 02:39 PM   #23
Moderator Emeritus
Not trying to talk you out of it but a screwmount and a k mount are different animals. You have to cut the flange off and also the aperture lever as well. I've seen a few posts on this. Then the lens is totally manual metering and from what I've read you also will loose infinity focus. Doesn't really make a lot of sense to pay upwards of $200 for a lens adapter that will be questionable on the Canon body.
On top of that the lens becomes worthless as I'd assume there would be very few Canon owners that would want it and Pentax owners wouldn't give you more than $50-100 for it used due to the cost of repairing it back to working condition.
01-24-2008, 02:53 PM   #24
Moderator Emeritus
This is taken from a Canon board that was discussing the trouble involved.
Unfortunately-as linked above-the pentax K mount models can't be adapted easily.
The problem is are the stop down lever and it's protector which protrude too far back .These don't allow the lens to be mounted back far enough to achieve infinity focus.
Apart from this there are no reasons they can't be used ,so if you have a particular favorite lens it would be possible to adapt it to EOS-you'd just have to remove the aformentioned parts and get a new mount plate machined up.Modifying one off an EF lens would probably be easier.
01-24-2008, 03:18 PM   #25
I guess I should have read up on this before I made the purchase. I have no problems modifying a cheap lens, but not an f1.2 Guess it'll be up for sale.
Shucks, I would have loved to try it out on digital.
01-24-2008, 03:26 PM   #26
amateur6's Avatar
QuoteOriginally posted by szk71 Quote
WOO-HOO!
*ahem* I mean, aw, that's a shame. Seriously, sorry.
...wait, I know -- just put the canon up for sale instead!
01-24-2008, 04:17 PM   #27
Finn's Avatar
Hey, that's easy! Buy a Pentax!
01-29-2008, 05:40 PM   #28
Barbecueboy's Avatar
QuoteOriginally posted by Sprags Quote
I'll trade the Nikon FM2 I have for an MX.
That was my favorite camera I had in the 80's.
I actually sold my nikon FE to buy my black (second) MX.
It makes sense with the wealth of K-mount lenses I have..
02-06-2008, 07:10 PM   #29
falconeye's Avatar
Since you are posting, though: if Google works for you, you may always access sites as follows:
Translated version of http://www.ebay.com/
:ugh:
02-06-2008, 07:29 PM   #30
jslifoaw's Avatar
If I recall correctly, the aperture lever only needs to get shortened for FF Canons. The mirror on others is small enough that it won't hit the lever when the shutter is fired.
I could be wrong, but this is what I heard. Otherwise I might have a 5D by now! (But no way in hell would I mangle my Pentax stuff just for FF)
lenses, mx, pentax, pentax mx
adapters for non-K-mount lenses to Pentax K-mount DSLRs: new dimensions for LBA Douglas_of_Sweden Pentax Camera and Field Accessories 152 07-29-2017 05:47 AM
For Sale - Sold: Genuine Pentax Mount Adapter K (M42 to K-mount) zx-m Sold Items 6 01-30-2009 01:22 AM
For Sale - Sold: *New* Pentax Mount Adapter-K M42 to K-Mount X Man Sold Items 4 12-31-2008 04:10 PM
For Sale - Sold: FA: Original PENTAX Screw Mount to K Mount Adapter M42 HogRider Sold Items 0 10-21-2007 02:12 PM
All times are GMT -7. The time now is 12:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
