Just to note the connections. What separates the M mode from the AUTO mode at dial level is a lever that pushes a small set of contact and turns on the Manual or Automatic part of the circuit. If the lever is damaged, either mode will not work or the contact is bent out of position and AUTO can not be powered up. If at the "Relay Board" (board with 3 fingers up) level, it is possibly that the wires were soldered wrong or shorted out. The solder points are about 2mm apart from each other and so it is possible that an error was made there. If you can have Eric re-look at it?
