Originally posted by TomB_tx I'm quite sure there is only one switch in the KX. As the shutter button is depressed half-way, and the wind-lever is out, a latch mechanism moves against the button shaft to keep it from going back up, locking the meter on. In the KX I believe the switch is activated by the movement of that latch mechanism, not the shutter button. (The movement of the button only allows the latch to engage.)
On the MX and LX the switch is activated by the shutter button itself, not the latch, so the meter activates whether the latch is freed by the wind lever or not.
I think that's why Eric is confused about doing this modification, as the switch would be activated by a different part of the mechanism.
Hrm, That elucidates the confusion. (I'm not sure why they would design it that way, though, but they obviously did.) Not knowing details, I suppose that means you could bypass the lot of it to be 'always on?' *thinking.* So, this means that in order to activate the meter, you must both have lever out and half-press-the shutter, and once both are done, you must fold wind lever in to turn it *off?* Hrm. I think what I'd do there would be to just bypass the whole electrical bit of that wind lever, and just make a nip in the top cover to let some wires out, and stick a little pressure switch like for a tactical light to the front of the camera.
(I'm pretty sure there's a cheapie Radio Shack version of this kind of thing, but I don't know how long they'd last) But, you know, make it purely electrical. Just take the wires, extend em outside the case, and hook em to a switch, of any kind, really.
Metering on demand.
