Show Printable Version 4 Likes Search this Thread
06-30-2012, 07:36 PM   #16
That is beautiful!
07-01-2012, 04:12 PM   #17
That is one b - e -a - utiful camera! Even better is that you are going to put it to good use!
07-01-2012, 07:55 PM   #18
gofour3's Avatar
Very nice, enjoy!
Phil.
07-01-2012, 08:01 PM   #19
PPPPPP42's Avatar
Keep all the original packaging and stuff, and be careful with it, rare doesn't begin to describe that, I'm not surprised it was from a collector. What did it cost anyways? I would be outright terrified to use it, but then things are made to be used, its a waste if they aren't, like my unissued (new, not refurbished) Yugoslavian SKS that I issued to myself.
Don't send it for CLA, Eric won't give that one back!
07-01-2012, 08:03 PM   #20
Yes I will! It costed me $300.
07-03-2012, 05:25 AM   #21
titrisol's Avatar
Location: In the most populated state... state of denial
GREAT DEAL!
The batteries work, just make sure you put them i nthe right direction.
To test:
- ASA dial in 100
- Speed dial in B
- Lift the lightmeter tab and the needle should plummet to the bottom
-> if it goes up battery is backwards
--> if it does not move battery is dead
QuoteOriginally posted by ChrisPlatt Quote
394/SW936/AG9 silver cells fit perfectly, give accurate readings and last a long time.
Wein Cells are several times more expensive and die after a very short time.
Chris
07-03-2012, 07:14 AM   #22
Aristophanes's Avatar
Battery options:
Cheap Easy Mercury Battery Replacement
WeinCell Batteries
And I think this one will work as well:
PX625 PX-13 replacement Nikon F Leica, Gossen, Canon
07-03-2012, 02:28 PM   #23
Otis Memorial Pentaxian
QuoteOriginally posted by Aristophanes Quote
Any modern silver cell of appropriate dimension should work. If too small a diameter, you can bolster the sides with a small rubber o-ring. Voltage should not be an issue. At least this works with my SP and SPII.
07-04-2012, 02:13 PM   #24
Bad News! The meter is behaving badly!
When I set the ASA to 100 and the shutter to B
The indicator only moved downwards slightly
But when I turn the shutter to other settings,
the indicator rapidly plunged upwards...
07-04-2012, 02:15 PM   #25
And when I change the aperture, the indicator doesn't move at all!
07-04-2012, 05:06 PM   #26
By the way, happy 4th of July from Canada!
07-05-2012, 05:49 AM   #27
Banned
QuoteOriginally posted by BenYe Quote
typically, cameras that sit in the box on a shelf for 40 years are less likely to work properly than cameras that got used. it may look mint, and you may have paid a hefty price, but this is the reality. my advice, if you really want to use the thing, you’re going to have to get it CLA’d. financially you would have been far better off, just buying a used one, if you really wanted to use it for its intended purpose.
07-05-2012, 06:05 AM   #28
SteveM's Avatar
I would send it into Eric for a CLA. If he can fix it, you'll end up a like new spotty with new seals etc that should last for another 40 years. You can find him at Home to see what he has to say.
07-05-2012, 03:47 PM   #29
Where is this shop in downtown Toronto?
07-05-2012, 03:56 PM   #30
Or just do like I did and learn to meter with your eyes.
It cost me very little and is a decent workhorse with solid seals and non sticking mirror although the meter didn't work. I didn't care to see if it does and am using it to get my Sunny 16 rules down as well as learning to do more candid Street Photography like photos.
Works beautifully just like your camera looks.
battery, indicator, shutter, spotmatic
Spotmatic F battery question zoltan1983snapper Film SLRs and Compact Film Cameras 33 06-11-2020 09:24 PM
For Sale - Sold: Spotmatic-F, SMC Takumar 50mm 1.4 (w/ Box, Like New Condition) joe.penn Sold Items 3 09-15-2011 08:51 AM
Spotmatic Replacement Battery theunartist Film SLRs and Compact Film Cameras 3 05-26-2011 10:31 AM
All times are GMT -7. The time now is 12:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
