Originally posted by TomB_tx In late1966 I went from my H1a to a Canon FT, and it already had the QL system - and the FT only came out in March that year, so I think the FT was always Quick Load. I also had an FP body (non-metered) sharing lenses, and it was not QL. The Pellix came out a year before the FT without the QL feature, but it changed to QL when the FT came out.
I also loved the meter and general build of these cameras. The FL lenses had diaphragm ring at the front of the lens, like rangefinder lenses, which I believe is why they tended to get sluggish diaphragms due to the linkage design. I noticed on my 50 1.4 and 200 lenses back then that at fast shutter speeds and small apertures the diaphragm would not be fully closed at the right edge of the frame, so under these settings this part of the frame would be overexposed. The diaphragms would seem snappy open and closed when operated by hand, so you had to test for this carefully. That moved me from Canon to Leica back then.
A couple years ago I found a mint FT with the same lenses for under $40, and ... these lenses had the same problem. I did a full CLA on the body and lenses, and by removing the oils from the lens linkages and polishing them with dry lubes instead they now work as they should. The FL 50 1.4 (ver II) still seems to have better "snap" and contrast than the Takumar 50 1.4.
Yeah, that's right.
That chassis was good for like fifteen years of production, and there's a TL in the family that might be three generations if one of my nephews ever picks it up.
I never actually had an FL 1.4, myself, (Did experience a 1.2 I think it was on a Pellix,) ...those FL 50s take diffusers *really* *really* well, though. I think it's cause they're essentially an adapted rangefinder design, or just how they're laid out. I used to have the proverbial 'Grandma's Nylons' to go with till they totally unravelled.
(Tiffen Softnets will do, but those old stockings really were magic.
As for build, yeah, about as bomb-proof as an SLR gets. You could cold -cock some psycho with one of those and photograph em a second later.
(This actually happened, kind of a random punk rock moment.)
