I recently got a K1000. Already shot a roll of film and results are good. Metering seems to be accurate, even a camera repair tech said so when I got the film (he took a quick look at it).
However, I'm experiencing the issue where the needle will not move unless there is sufficient light. For instance, it will not work inside a restaurant at night (not a candle lit table)
. I read about people saying they didn't like the needle metering as you couldn't read the metering in low light, but I'm not even close to not being able to see the needle, as the whole thing won't work well before that. I read somewhere that if there is enough light for one to read the camera should be able to pick that up.
Is it possible that I'm getting accurate readings with good light but that something is causing it not to work under lower light conditions? Seems strange.
Thanks!
