07-30-2012, 02:06 AM   #1
K1000 firing pin problem
Hello all.
Recently picked up a K1000 from a secondhand store for just $20Nzd (with 50mm f2!). Did a test roll and everything was fine. Got prepared to do some night long exposure only to find that it wouldn't fire the shutter. Anyway after taking off the top following the service manual it seems the cable release pin was simply stuck, which was rectified with pliers and a heart turn. Now a couple of questions: could there any other factors, like a stray piece of machinery stuck in the camera somewhere? And for when I reassemble and put the cable release pin back, should I clean it with lighter fluid and put it back dry or use some silicon grease to keep it lubed?
Sorry if this should be in a different forum. First time poster but have gained a lot of useful info from browsing this forum!
Cheers
Greg
07-30-2012, 08:06 AM   #2
Giveaway winner!
MysteryOnion's Avatar
If the ability of a release cable is in question only, then it is just that post is the question. If the shutter button is also poorly functioning, then the problem will extend from post-release bar-the rod under the reaches the button- the bar that is attached to the tripping arm to the mirror as well as the other side of the release bar to the first curtain release. Lube the little post that inside the release button, but I would not recommend dropping grease anywhere else. Dry lube should be an ultra fine type... still you should discover if a bent or maladjusted rod (release shaft) is to blame. If you are working from the "National Repair Manual", do look around page 45 to 49 for examples.
07-30-2012, 09:09 PM   #3
Thanks MysterOnion. Have determined from your post everything else is fine; the problem was just with the pin.
But a new problem has risen out of my ineptitude - I shut the back cover with the top off. I don't know how to perform the action that opens it normally when you use the rewind knob. What do I need to do to get the back open again?
Cheers
07-31-2012, 07:47 AM   #4
Giveaway winner!
While the top shell is off... and from memory right now.
Look for a spring like bar that is under the circuit board. It has contact with the edge of the camera body where the latch is located and you should be able to slip a driver under the spring/bar/leaf and lift up to raise the latch to open the door.
I can furnish a picture later unless someone else uploads one here first.
07-31-2012, 12:12 PM   #5
Sluggo's Avatar
I don't have a parts k1000 here, but assuming it's like a Spotmatic, I think MysteryOnion is referring to the bar shown with the red arrow. Lift or pry that up, and the door pops open.
07-31-2012, 03:41 PM   #6
So simple! Thank you MysteryOnion & Sluggo. Now to put it all back together...
08-01-2012, 04:16 AM   #7
Giveaway winner!
Thanks Sluggo, I knew someone would have a chance to drop a snap in for geg_thomas.
08-02-2012, 02:23 PM   #8
Everything's back together and working smoothly. Thanks again.
cable, forum, k1000, pin, release
k1000 light meter problem chris* Pentax Film SLR Discussion 16 09-06-2015 10:42 PM
K1000: Problem with film advance summernolan Troubleshooting and Beginner Help 7 04-14-2011 12:39 AM
M42 Voigtlander 90 Aperture Pin Problem Sirfishalot Pentax SLR Lens Discussion 4 01-15-2010 02:33 PM
Pentax AF-540 FGZ Locking Pin problem survey Sprags Pentax Camera and Field Accessories 30 01-16-2009 12:25 AM
Help the newbie with a K1000 problem! mguidry Troubleshooting and Beginner Help 12 05-26-2007 10:45 AM
All times are GMT -7. The time now is 09:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
