Originally posted by Colbyt In my limited experience I don't think so, mainly because of image size. I learned this one the had way after shooting some neon signs in fairly dim lighting.
Colbyt, do you think this effect might have to do with why I have been having trouble getting sharp images with Super Takumar 28 and 50 lenses under dull artificial light with UV filter on? The problem is the images frequently appear soft or very soft even though the focus scale seemed set right for the distance and the image in VF seemed sharp. The effect is not noticeable on the other 8 takumars which have rounder front elements.
I am speculating, more reflectance because of single coating, which then has several reflection cycles, each moving the light sideways a bit, and hence the softness.
