08-15-2012, 12:44 PM   #1
Pentax MZ-S with home-loaded film cannister
When I use plastic home-loaded cannisters with my Pentax MZ-S body it does not rewind the film at the end of the roll. Starts to rewind, but after a second it stops and gives an error message. It does not even work with the manual rewind button. I do not know exactly if it has something to do with DX coding but my guess is that it has. My other thought that I might need to set it in the Functions. Don't know.
So when I use home-loaded cannisters with the MZ-S I have only one roll to go as I can take them out in the darkroom only (have no changing bag to take with me).
Any similar experience with other AF bodies? Or maybe a solution?
08-15-2012, 02:15 PM   #2
I have the same problem with my MZ-30 & ZX-7. I think its a combination of the felt light trap being tight and a weak rewind mechanism on this series of cameras. My SF1 works fine with them.
08-15-2012, 03:23 PM   #3
I'll drill a hole on my MZ-S and install a good old rewind shaft then Might help in these cases.
08-15-2012, 04:38 PM   #4
QuoteOriginally posted by Zivelot Quote
Hmmm, let me think . . . I don't see a down side to that, I think you should
Back to being serious, I am curious if metal re-loadable cassettes work with these cameras. Anybody use metal cassettes?
08-19-2012, 11:02 AM   #5
Seems like a good idea trying metal casettes. I might invest in one or two to see how they work with AF bodies.
08-19-2012, 12:30 PM   #6
ChrisPlatt's Avatar
Plastic cassettes seem to require more effort advancing/rewinding manually too.
I suspect the thicker walls leave less space for the coiled film, resulting in more resistance.
I also recall that the ends of the plastic cassettes I used tended to come off rather easily during normal use.
Chris
08-20-2012, 01:19 AM   #7
G and T's Avatar
I have only ever used metal cassettes with my MZ-S and have never had the problem that you have. That certainly points the problem at the
plastic cassettes that you are using.
Glenn
08-20-2012, 02:10 AM   #8
That is what I suspected. I have never had any problem with factory loaded casettes in my MZ-S. Will start looking around for some metal casettes or just figure out how I could reuse the empty ones.
10-20-2012, 03:21 PM   #9
Just a quick update.
I bought a box containing a Burke & James bulk loader and 30 metal cassettes from my local camera shop. I've run several films through the MZ-7 using the metal cassettes without a problem. I've even noticed that the advancing film doesn't bog down the motor like the plastic ones did.
film, home-loaded, mz-s, pentax, pentax mz-s, rewind, roll
Mirror problem when recharged battery is loaded Mantisman Pentax K-5 6 08-08-2012 03:42 AM
Question How to view down loaded photos! WillH Site Suggestions and Help 10 08-04-2012 07:39 AM
Weight of your largest bag fully loaded daacon Pentax Camera and Field Accessories 21 09-04-2011 12:48 PM
Film--free to good home billmcf Pentax Film SLR Discussion 9 10-12-2010 01:44 PM
For Sale - Sold: Pentax BG-2 Grip Fully Loaded! augustmoon Sold Items 9 02-01-2009 07:15 AM
All times are GMT -7. The time now is 08:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
