Originally posted by cyrene Although I know that this flash won't communicate in any way with the K1000, it appears to fit in the hot shoe. This is the only flash I have, and I'm still a very green newbie at using it. Any reason why it won't work on the K1000? Might it work in "A" mode?
Works on my MX in "A" and "M" modes with no problems. If you leave it in P-TTL it will still fire at full power, as it would in "M" mode at 1/1 setting. In "A" mode you will have distance range based on ISO and f-stop, in the "M" mode there is no distance indicator since flash does not know what aperture is set.
Also, change ZOOM control to manually set FL to match your lens and you are good to go.
