Originally posted by CMG Thanks very much for that really helpful info! I wasn't aware of his formula...but it does make sense! If I purchased an M 50mm f/1.7 how would I use it on my K-5? I shoot manual most of the time as is, but I know that his lens will not communicate with the camera.
Someone else already showed you the link to using manual K-Mount lenses, and it's not hard to do.
But, if you bought an A 50mm f/1.7, you could use the aperture ring when it's on the MX, and leave it in the "A" setting when it's on digital. Then you can use it like an autofocus lens, only without the autofocus. The M and A f/1.7 lenses have the identical optical formula and are the same size.
The downside is that the A lenses don't have the same wonderful build quality as the M lenses, and cost a little bit more than the M equivalent because people know they're more convenient on a DSLR.
The 31mm on an MX ought to be wonderful, too!
