09-13-2012, 07:22 PM   #31
Canon introduced their QL - Quickload, feature back in 1965. Now that I know how the magic fingers work, I can load my LX (as well as MX and ME Super) in complete darkness and get up to 40 frames from a 36 exposure roll.
09-13-2012, 07:49 PM   #32
hks_kansei's Avatar
The odd thing is I don't really like the magic fingers thing, I much prefer the older system on the SP1000.
I'm always paranoid with my ME that the fingers won't hold and the film won't wind on. (I need to very carefully advance the first couple of frames to make 100% that it's on correctly)
09-13-2012, 07:57 PM   #33
You don't have to be careful about it at all. You simply insert the film in there at least 1/4 - 1/2 inch in and you're set. I believe you can push it in there even more if you are paranoid.
09-13-2012, 08:03 PM   #34
Pioneer's Avatar
QuoteOriginally posted by LesDMess Quote
In the beginning I was not comfortable at all with the magic fingers but to be honest, once I learned how to use them, this is one of the only 35mm cameras I own where I have never had a missed load. Les is right, it is a very reliable system and very easy to use, night or day.
09-13-2012, 08:22 PM   #35
tabl10s's Avatar
It was even praised by the mags of the time and is patented.
09-13-2012, 09:49 PM   #36
grhazelton's Avatar
Amazing what will eventually surface in one's memory! "Magic fingers" was the moniker of an electric massaging mattress of many years ago! I think Pentax called their takeup spool Magic Needles.
09-14-2012, 04:05 AM   #37
tabl10s's Avatar
Bwahahaha! We're getting old.
09-14-2012, 04:19 AM   #38
That's what they say is the first thing to go . . .
09-14-2012, 07:42 AM   #39
unixrevolution's Avatar
QuoteOriginally posted by SCADjacket Quote
It all makes sense now, it was just me not knowing what I was doing that was causing the issue.
Hopefully the more I learn the fewer stupid things I'll do.
If you're anything like me, you'll just be stupid on different, more innovative levels
For instance, not knowing how to even load film into your new 4x5 view camera.
09-14-2012, 08:30 AM   #40
grhazelton's Avatar
QuoteOriginally posted by tabl10s Quote
Beats the alternative, doncha think?
09-14-2012, 09:03 AM   #41
tabl10s's Avatar
Growing up all over again?
09-14-2012, 12:52 PM   #42
Otis Memorial Pentaxian
Just make sure that the sprockets are engaged top and bottom and all will be good. The sprockets are the actual drive mechanism.
09-14-2012, 12:53 PM   #43
QuoteOriginally posted by unixrevolution Quote
...you don't...
09-14-2012, 01:04 PM   #44
Ben_Edict's Avatar
Thanks for the correction on number 2.
I should also further qualify that although I've tested quite a few cameras in search for the LX's unique long duration metering, I only managed to test a few models and have not accounted for all models and variations. If there is another camera out there - from any manufacturer, that embodies the seemingly unique capabilities of the LX, I am not aware of it!
The original patent for OTF is Minolta's, by the way. Olympus used it first and Pentax implemented it extremely well.
Ben
09-14-2012, 01:10 PM   #45
Ben_Edict's Avatar
One question, Automatic Mode (aka Aperture Priority) either doesn't work, or I'm doing it wrong. Anytime I set it to Auto, set the aperture and press the shutter release the mirror pops up, but never comes down.
It doesn't stick in the way of "Sticky Mirror Syndrome" It works fine in everything but Auto... any ideas?
To get the mirror to drop I have to switch the SS knob off of Auto.
Gonna give it some more time before I make the call if I want to buy it from my buddy.
Locking up the mirror is usually a sign of a low battery capacity. I think, that is even included in the manual somewhere.
If the mirror drops down, when you switch Auto off, it probably isn't the sticky mirror syndrome, because that is independent of the shooting mode...
Very long exposure times in Auto-mode do happen, by the way, if there is no film loaded, as the metering takes its reading then off the black pressure plate during exposure.
This OTF metering always led to confusing results, when I attached the LX to a shutter speed measuring device: all the short times (reading off the printed first shutter curtain) were fine, and the longer speeds (reading off the pressure plate) were way off. That confused a couple of engineers, but I never told them the reason and left them confused...
Ben
camera, fe, focus, lx, pentax, pentax lx, quality, screen, size, system
Experience with Pentax - trying to understand Olympus Trojan_Llama Film SLRs and Compact Film Cameras 8 09-06-2012 11:22 AM
I mustn't understand the Quick-Dial - if I do, Pentax are deliberately being daft tclausen Pentax Q 11 07-26-2012 02:15 PM
Black & White i do NOT understand modern art.. dcmsox2004 Post Your Photos! 11 03-03-2011 07:48 PM
Swedes, help us understand mikemike General Talk 37 12-16-2010 03:21 AM
Please help me to understand what with my 31mm/1.8 Neco Pentax SLR Lens Discussion 20 11-07-2010 11:14 AM
All times are GMT -7. The time now is 12:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
