09-12-2012, 07:25 PM   #1
hks_kansei's Avatar
Simple question re: Daylight film
Simple question here.
I'm going to attempt to take a nice sunset image after work on my ME, it's currently loaded with Fuji Superia 200asa which is a daylight film.
How will this affect the sunset colours? will the colours shown on the developed film be approximately what my eye will be seeing? or will the sunlight rating of the film tend to reduce the colours visible?
I've not done any sunset photography before, and I've certainly not tried on film. I just want an idea of what I might end up with.
Thanks.
09-12-2012, 07:53 PM   #2
Canada_Rockies's Avatar
Daylight film is best to retain the orange sunset colours. If the print is not the right colour, simply get it reprinted with the corrected (or enhanced, if you wish) colours.
09-13-2012, 12:26 AM   #3
hks_kansei's Avatar
Thank you, Canada.
I said it was a simple question, answered in one!
09-14-2012, 01:14 PM   #4
Ben_Edict's Avatar
I would like to expand a bit on Albert's explanation: You often will get a "colour corrected" print from an automated printer with these sunset shots. The printer will analyse the negative as having excessive reds and try to get a neutral print, if the operator does not prevent this correction. So, write a note on the bag, when you hand over the film and ask them, not to correct the reds.
Ben
09-14-2012, 08:37 PM   #5
A simple rule would be to use daylight film when the light source is the sun. This is true in the morning, in the evening, and anytime in between. Ditto for moonlight (reflected sunlight). Use tungsten-balanced film when the light source is incandescent (tungsten filament) bulbs. If you are shooting under fluorescent...tough luck...
09-14-2012, 09:38 PM   #6
gofour3's Avatar
If you also plan to shoot in the evening before the sun starts going down, a Morning & Evening (82A) filter is recommended. It's slightly blue and removes the yellow/reddish effect you can get when using colour daylight film at that time of day. Pentax used to make one for 35mm and 6x7.
Phil.
colours, daylight, film, question, sunset
Simple focusing screen shim question timo Pentax DSLR Discussion 12 05-05-2012 05:58 AM
Simple flash question SgtSmurf Troubleshooting and Beginner Help 2 10-13-2011 05:20 PM
Simple question about the 67 105mm lens Yamanobori Pentax Medium Format 7 03-23-2011 05:22 PM
Has digital taken the fun out of a good simple film shot? Peter Zack Pentax Film SLR Discussion 69 11-07-2009 06:20 PM
just a simple question LeGoGubbe Photographic Technique 4 08-20-2007 11:19 AM
All times are GMT -7. The time now is 10:02 AM. | See also: NikonForums.com, part of our network of photo forums!
