11-13-2012, 07:03 PM   #1
K1000 Problem?
I just got a K1000 in the mail today and, like most people would, started playing with it. I then had the advance lever jam and opened it up to try to see what was wrong. (No film in it)
The rubbery-cloth bits (sorry, I don't know the name) are in between transitions. That's all I can see. Then I noticed that the advance lever wasn't springing back properly.
I don't know what to do... Any advice?
11-13-2012, 07:17 PM   #2
gofour3's Avatar
The shutter may be stuck open, have you tried turning the shutter speed dial? What happens when you press the shutter button?
Phil.
11-13-2012, 07:20 PM   #3
QuoteOriginally posted by gofour3 Quote
Phil.
Nothing happens when I turn the speed dial. When I press the shutter button, I can only depress it about half way and nothing happens.
11-13-2012, 07:38 PM   #4
Here's a picture if it'll help.
11-13-2012, 07:40 PM   #5
That would be a shutter stuck mid-way, apparently during cocking. Alternatively the leading curtain may have jammed on release and the following is jammed up against it. Either way, it will need some skilled attention.
11-13-2012, 07:50 PM   #6
By "skilled attention" I assume you mean someone who (unlike me) actually knows what they are doing?
11-13-2012, 07:58 PM   #7
patrick9's Avatar
I would contact Eric. I don't have his link at hand, but can get it if you are interested. He is good ,reasonable, and highly recommended here on the Forums
11-13-2012, 08:00 PM   #8
QuoteOriginally posted by patrick9 Quote
He can be found at: Home
11-13-2012, 08:03 PM   #9
Giveaway winner!
MysteryOnion's Avatar
I noticed that the inside is very dusty. In the front of the camera under the lens is the mirror. Is it in the up position or is it still in the down and you can look through?
11-13-2012, 08:05 PM   #10
QuoteOriginally posted by MysteryOnion Quote
I thought it was down. It is up.
11-13-2012, 09:09 PM   #11
Giveaway winner!
If the mirror is up, it is either supposed to go up allow to fire the shutter or to come back down to finish and unblock the winding system.
Since you reported the winding being stuck, then we must have a issue with the release of the shutter. The picture seems to show both the curtains. So the first curtain must be stuck or the second curtain release prematurely. Do you know what speed or number the shutter dial (that would be the dial on the top part of the camera that has a B and numbers 1 to 1000) was set to when it stopped working?
11-13-2012, 09:19 PM   #12
I do believe that it was either "B" or 60. At least, those were what I'd been playing around with most...
11-13-2012, 09:21 PM   #13
Is this the K1000 you bought from me on the marketplace? It worked before I sent it! Try pressing the shutter button, then pulling the film advance lever all the way forward, then try the shutter button again. It should fire!
11-13-2012, 09:26 PM   #14
It was working... It just kinda... stopped while I was playing with it.
While typing this, I freed it. I used a bit more force (I was afraid to til now) It works now.
11-13-2012, 09:29 PM   #15
QuoteOriginally posted by SpartanD63 Quote
It was working... It just kinda... stopped while I was playing with it. While typing this, I freed it. I used a bit more force (I was afraid to til now) It works now.
Ok- but please do shoot me a PM if you have any further issues with it
advance, k1000, lever
k1000 light meter problem chris* Pentax Film SLR Discussion 16 09-06-2015 10:42 PM
K1000 firing pin problem geg_thomas Pentax Film SLR Discussion 7 08-02-2012 02:23 PM
K1000: Problem with film advance summernolan Troubleshooting and Beginner Help 7 04-14-2011 12:39 AM
k1000 shooting problem fusionimaging Pentax Film SLR Discussion 7 11-14-2009 05:43 PM
Problem with K1000 mirror mhoy Pentax Film SLR Discussion 5 04-26-2008 07:19 PM
All times are GMT -7. The time now is 02:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
