12-24-2012, 03:13 AM   #1
MX Shutter Speed problem
Hi,
Bought a MX had it CLA'd just got it back gave it as a Christmas gift and have just been informed the shutter speeds are not working properly.
Apparently regardless of which shutter speed is selected they are all the same speed. We've tried turning to 'B' pressing the shutter release button and holding it the shutter doesn't stay open.
I've googled till my fingers were sore.... could this be that thelubricant hasn't worked its way through the shutter mechanism or is this indicative of a more serious problem?
Any help would be appreciated.
Thanks
12-24-2012, 06:01 AM   #2
Giveaway winner!
MysteryOnion's Avatar
That just sounds odd...
QuoteOriginally posted by angrywaiter Quote
Bought a MX had it CLA'd just got it back gave it as a Christmas gift...
Properly serviced, the speeds are going to be fixed. The only thing that might be is missing parts that connect and work the "delay" actions of the low speeds or the connections to the high speed lever.
CLA'd means that lube issues were all taken care of.
It has been a little while since I've been inside my MX bodies, but it sounds like the only speed you should end up with if all levers are stuck is 1/60?
Was the camera damaged by water?
12-24-2012, 06:21 AM   #3
QuoteOriginally posted by MysteryOnion Quote
Hi,
Thanks for the response. Although there was no water damage to my knowledge, you correctly diagnosed the underlying problem.
Literally I jumped on a Tube and took the MX to Harrow Technical. Robin solved the problem in 5 minutes. Broken spring on the slow speed delay mechanism. He changed the spring, tested the shutter speed timings and got it fully functioning again. Really impressed with the service.
Thank you for taking the time to respond. I appreciate your advise.
12-27-2012, 09:51 PM   #4
Hi,
Thanks
If you paid for a CLA and the camera is behaving as you describe, I do believe that a discussion with the service facility is in order. A properly CLA'ed camera should operate smoothly with accurate shutter at all speeds.
mx, mx shutter, shutter
p50 shutter speed problem pocoyo Troubleshooting and Beginner Help 2 06-08-2011 12:15 PM
Aperture/shutter speed problem with 50mm f/2 vcw79 Pentax SLR Lens Discussion 5 03-25-2011 07:02 AM
Pentax KX Shutter starting to stuck at slow shutter speed. Spirit722 Pentax Film SLR Discussion 7 03-03-2011 09:49 PM
Shutter speed problem??? Pic_Colo Pentax SLR Lens Discussion 3 12-24-2008 12:07 PM
ME Super Shutter speed problem clawhammer Pentax Film SLR Discussion 5 11-10-2008 12:44 PM
All times are GMT -7. The time now is 01:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
