All around the World said me: It is unreal to find new. The best case you can find batteries, manufactured 2004.....
So, I find a radical solution of my trouble: two 8.4 V battery CR-9V size. To correct voltage I use a STI L7815CV voltage regulator.
But the first version of modification have one feature - it can be used only 48 hours after charged
I connect voltage regulator before the power on-off switch. That is wrong because my charge leaks out through voltage regulator.
In the new version voltage regulator will work only when my LX NiCd Battery Pack switched on.
