08-11-2014, 04:12 AM   #1861
QuoteOriginally posted by Mattco26 Quote
Where did you find that? I'd love to have something like that for my K-01 that doesn't cost so much.
I bought it as part of a job lot. It is a Sony DSAC-MVC eye level viewfinder. I came unused in its box, which is important. The blank protection plate that attaches the viewfinder while packaged is required to customise the the piece. I cut a window into the blank then glued the modified blank to the camera with double sided tape. This now serves as the mount attachment meaning that the viewfinder can be detached when needed.
I have not seen any for sale of late. I suspect it will be hard to find.
Mark
08-11-2014, 04:33 AM   #1862
Digitalis's Avatar
08-11-2014, 04:47 AM   #1863
Jonathan Mac's Avatar
A second MZ-5N and huge Sigma 28-70 f/2.8 to use with it. I usually use manual cameras and primes for film so an AF zoom will be a bit of a novelty.
MZ-5N with Sigma EX DF 28-70 f/2.8
by Jonathan_in_Madrid, on Flickr
08-11-2014, 06:18 AM   #1864
Marketplace Reseller
dcshooter's Avatar
How is the weight balance with such a large lens? The MZ-5n is not exactly a hefty camera.
QuoteOriginally posted by Jonathan Mac Quote
---------- Post added 08-11-14 at 06:51 AM ----------
Yeah, moving/flying insects are the big example (for which AF w/ MF adjustment can be quite useful), plus small objects in the wind or shooting anything handheld, since DOF can be hard to catch just right without a fast shutter. Having owned and used both, the K-01 shutter is slow as molasses to actuate compared to the K-5 or K-3, which is surprising, since there is no mirror to move out of the way. Although not so surprising, I suppose, since the K-01 is intended as more of a "style" cam than as a performer.
Admittedly, the added on-VF seems to be a nice solution.
QuoteOriginally posted by Wild Mark Quote
I use it for static objects although I must admit I am unfamiliar with action macro - perhaps bugs? I tend to like photographing wild flowers and bugs, with the latter a little tricky from time to time.
The viewfinder makes the screen bright and easy to see in bright sunny conditions as I use focus peaking and manual focus - so AF is not an issue for me. Works a treat!
Re: unresponsive shutter? Unsure what you mean there. I use an infra red controller to release the shutter -
08-11-2014, 07:10 AM   #1865
QuoteOriginally posted by dcshooter Quote
The balance is ok because the weight is close to the camera body and because the DF (dual focus) system allows the focusing ring to disengage from the AF system, which means it can be held to support the gear.
Still, I suspect a battery grip would be beneficial, and I might look into getting one shortly. The grip is the FG, I think.
08-11-2014, 07:57 AM   #1866
QuoteOriginally posted by edmundrt Quote
It appears to be based on a well-used chassis from the 60s/70s, which can also be seen on the Chinonflex TTL, Cosina Hi-Lite and (I think) Nikkormat FT/FTn. I've seen discussion online as to where this body originated, and the consensus seems to be that it was either Cosina or Chinon. If anyone here has a definitive answer I'd be interested to know.
It is not definitive, but the history as I understand it is that the original Nikon version (Nikkorex F) was a collaboration between Mamiya and Nikon in the early 1960s. Shortly thereafter Ricoh acquired the design and tooling with the original Singlex (also in F mount with a Ricoh-made lens) being made in the same factory. Subsequent models of the Singlex were in M42 screw mount. Nikon, on the other hand, modified the design to create what was to become the long-lived Nikomat/Nikkormat series bodies.
All Singlex and Nikkormat models shared the same Copal "Square" vertical travel metal shutter. Ricoh modified the design by moving the shutter speed dial to the front of the camera. This allowed for a simplified direct geared linkage to the shutter mechanism rather than the complicated 90 degree turn of the original Mamiya design. I shot with a Singlex TLS as my camera for about a decade and really came to appreciate the front-mounted dial. It is much easier to use than a top-mounted design.
As for the Cosina/Chinon rumors. It is my belief that the rumor arose due to later cameras (think 1970s) bearing the Cosina and Chinon names that also had the Copal shutter and the distinctive front-mounted shutter speed dial. Whether these were made by Ricoh and rebranded or made under license or a completely different camera...who knows. The Singlex TLS was probably the most widely rebranded camera in history with the Sears label being the most common.
http://camerapedia.wikia.com/wiki/Ricoh_Singlex
http://www.cameraquest.com/nfrex.htm
http://www.cameraguild.jp/nekosan/singrex.htm
Last edited by stevebrot; 08-11-2014 at 08:25 AM. Reason: Accuracy and completeness
08-11-2014, 09:44 AM   #1867
Mattco26's Avatar
I think this perception is because the K-01 first has to close it's shutter. Shoot your K-5 or K-3 in live view mode and compare.
08-11-2014, 11:03 AM   #1868
Ricoh Singlex - Camerapedia
Nikkorex F
Ricoh Singlex
Thanks Steve! I always like to know the history of my cameras. The front-mounted dial is nice, and it keeps the area around the shutter button uncluttered, IMO the best thing to appear on a variation of this body was the Nikkormat's top-mounted DoF preview button just to the left of the shutter release - perfect for that last check before you click.
08-12-2014, 10:10 AM   #1869
hoopsontoast's Avatar
08-12-2014, 01:24 PM - 1 Like   #1870
08-12-2014, 01:41 PM   #1871
Jean Poitiers's Avatar
An Edixagon 50/2 ... apparently quite rare and supposedly made by Rodenstock ... needs a bit of cleaning
08-13-2014, 10:55 AM   #1872
Who can resist buying a 3 thrift shop Polaroid Spice Cam from the late 90s. I can not. Spiiiiiiiiiicy!
08-13-2014, 11:43 AM   #1873
Swift1's Avatar
My first foray into integral film.
08-13-2014, 04:10 PM   #1874
arnold's Avatar
QuoteOriginally posted by Jean Poitiers Quote
Looks like it may have six pieces of glass. Tessars are usually f2.8. Interesting.
08-13-2014, 05:34 PM   #1875
MD Optofonik's Avatar
The grab & go shelf.
The grab & go shelf. I propped out the Q a bit; that red dot with the FA 55 would be overkill in the real world. Having an f1.4 280mm telephoto in such a small package, however, is something I'm looking forward "grabbing" this weekend. Sans the red dot, of course. It will be the Q's maiden voyage.
PENTAX K-30  Photo
645n, af, bronica, camera, chris, ebay, eric, f2.8, fa, film, flickr, lens, mx, nettar, p3, p30t, pentax, photography magazine, post, praktica, retina, shutter, site, store, stuff, swap, test, thrift, tools, winder
The "Keeper" Lens Club -- You'll regret it if you sell it. vandamro Lens Clubs 92 09-18-2016 10:09 PM
Is it safe to share my personal collection of K-01 lens p0rn? elpolodiablo Pentax K-01 41 03-01-2013 11:16 AM
If you aren't using it, zip it up! The Jannie Pentax DSLR Discussion 17 09-16-2011 04:35 PM
You've got to love technology and it's mindlessness mtansley General Talk 6 07-24-2011 05:43 PM
Cityscape Got one I'd like to see what you can do with it photolady95 Photo Critique 9 06-25-2011 01:27 PM
All times are GMT -7. The time now is 11:56 AM. | See also: NikonForums.com, part of our network of photo forums!
