11-08-2014, 07:26 PM   #2266
Cuthbert's Avatar
I see your point, never had a focusing problem with a slr until now (while some rfs are iffy) but today I made a small experiment and got convinced the mirror is the problem. I focused an object at about 2.5 Mt from means measured the distance using the scale of the lens as a tachimeter: My K1000, MX and FM measured something between the 3 and 2, they were consistent, the LX is convinced that the distance is over 3 meters. I used a piece of paper to &quot;shim&quot; the mirror under its central cushion and I noticed I got about the same distance as the other cameras, of course if the mirror is lower the distance measured by the lens would be greater and the result will be a backfocus, so I need to raise that mirror somehow...and I also checked if the screen was the problem, bad idea: The seal of the mirror is destroyed and all the dust went on the screen and the glass above it (lx and mx have another element, unlike Nikon and canons...the result is that I couldn't clean them as before and the viewfinder that was crystal clear now is sh!t...I feel stupid!<br />
<br />
However, I see a lot of potential in the lx, I have already started to buy the accessories I need in a camera (grip, hood, eyecup etc..) but I'm unimpressed by the 1.7 to be honest, a soviet Helios is Imo a much better choice, I'm sorry not to enjoy the camera as I should for this stupid problem.
11-09-2014, 01:01 PM   #2267
If the camera is fundamentally in good condition then I'd spend the money on the CLA.
I've often thought that if I could afford an LX I'd probably buy a tidy but jammed example and have it repaired. There's just as much chance of a working example locking up at some point, at least that way I'd have one which had been serviced. The price of camera plus CLA would probably be about the same as the price of a working example.
As things stand I'm happy with my KXs and MXs. Yes, I could probably sell them all and buy an LX, but the K and M bodies are simple enough to DIY repair. I have an MX on test at the moment which came to me as a stripped hulk with a dead light meter and non-functional flash connections. After replacing the missing parts and some strategic bending of contacts it seems to work fine, the shutter sounds right compared to a known good example. I doubt an LX would take kindly to the same treatment!
11-09-2014, 01:14 PM   #2268
Jean Poitiers's Avatar
Made a few score at the Nantes swap today ... Will post some images of the swap and the gear tomorrow ... Cheap post for "Post-a-thon" contest
11-09-2014, 01:30 PM - 1 Like   #2269
Cuthbert's Avatar
QuoteOriginally posted by Dangermouse Quote
Today I made a little experiment shimming the mirror with some paper and it appears it's 0.5 mm lower than where it is supposed to be, perhaps I might try and emergency repair before sending the camera to CLA.
However these are my K1000 and MX:
I assume the K1000 is an early 1976 model, one still made in Japan:
It has a SMC 55 mm f2.0, gofour said it was the lens meant to be sold with the K1000, first production run.
The MX is a piece of junk, it arrived so dirty that I could barely see inside the viewfinder, the shutter speed wheel was off and the lightmeter didn't work, now it's in working but outside still looks pretty bad:
The LX feels slick and smooth, a pity for this problem because IMO is a camera of another class, much more sophisticated:
Almost like a sort of Leica M3/4 equivalent in the SLR range...a pity it's underrated.
QuoteOriginally posted by Jean Poitiers Quote
Keep us informed!
11-10-2014, 03:17 AM   #2270
QuoteOriginally posted by TomB_tx Quote
One of the causes of "sticky mirror" on the LX is a softening of the pad that the mirror rests on when down in the focusing position.
I'm a little late to jump in with my LX experience but anyway...
The rubber pad was clearly the cause of the sticky mirror in my case, making the mirror stick if the camera was not released for a while. So the immediate workaround is to get the mirror loose using the MLU before shooting. That said, I managed to replace the pad with a rubber piece cut to fit that I glued in and it worked OK with some trial and error concerning the thickness for proper focusing. If the mirror position is off it will be more of a problem with wide angle lenses where a little movement of the lens while focusing makes a lot of difference. Long lenses are less sensitive to this issue. I don't have my LX body with me but there might be an adjusting screw inside the mirror box too -- but if there is I did not touch it.
Finally, if the question remains, I can confirm that the M eyecup fits the LX (couldn't live without one and tended to lose/break them, so I still have two or three lying around).
11-10-2014, 07:23 AM - 1 Like   #2271
Having managed to hunt down some M series lens hoods I thought a portrait of my examples of the first M bodies was in order:
11-10-2014, 07:25 AM   #2272
Excellent ... they look great. Must be nice, J
11-10-2014, 07:38 AM   #2273
The ME was a lucky find on ebay. Nobody else bid, so I got a minty black ME with the nicest M 50mm f1.7 I own, original lens cap, original strap, the case that had protected it since new and the manual with the original guarantee slip for £25. I replaced the light seals, fitted a couple of new batteries and got a perfectly exposed roll of film back.
The MX was listed as spares or repair, turned out it needed a good clean, new light seals, and a new focusing screen. I fitted a spare grid one I had hanging around which has a couple of small marks. The light meter was overexposing by about 2/3rds of a stop on arrival but after a lot of wiggling the ISO dial it seems to have calmed down.
11-10-2014, 07:49 AM   #2274
Very nice ensemble!
11-10-2014, 07:51 AM   #2275
That's a great haul on the ME and glad to you worked out the MX ... I would like to have a black one. J
11-10-2014, 08:02 AM   #2276
Cuthbert's Avatar
I'm also waiting for the same hood with case for my LX.
11-10-2014, 08:48 AM   #2277
Black MXs are hard to find, I don't see that many for sale. I also have a minty chrome one which I picked up in similar circumstances to the black ME, but paid a bit more for. Oh, and two slightly rough chrome ones. One was my first MX, the other the repair project now being film tested.
MEs apparently breed in my cupboards. I have another minty black one and three chrome ones with varying levels of scuffing! I think they're often unfairly overlooked, the black versions with an M 40mm and fast film are very nifty for parties.
Lens hoods seem to suffer from one or two ebay sellers convincing people that they're rare and should be expensive. I refuse to pay £35 for a lens hood, which one seller seems to consider the going rate! Problem is, anyone else listing one will follow suit and hey presto you have a situation where if you want one you're paying that much. I waited for ages to find one at a price I considered sane.
11-10-2014, 08:55 AM   #2278
My silver MX and Spot F that I sent off to Eric ... and I now have a SMC Tak 50/1.4
Would love to have a black of each of these guys. (re-post)
I have a black and a silver (several) SR-T 101 ... it's fun to see them side by side. J
11-10-2014, 10:22 AM - 1 Like   #2279
JuanEstrada's Avatar
Hi you all!
My LX is with Eric so no LX pictures this time, but I think thisis very p0rny...
Olympus OM 180mm f2
And those bellow are the results at f2...
hope you enjoy!
Canon EOS 6D  Photo
Canon EOS 6D  Photo
Canon EOS 6D  Photo
Canon EOS 6D  Photo
11-10-2014, 10:24 AM   #2280
QuoteOriginally posted by JuanEstrada Quote
Hi you all!
Olympus OM 180mm f2
hope you enjoy!
Nice !!! Are you going to get a Multi-Mount for it ? J
645n, af, bronica, camera, chris, ebay, eric, f2.8, fa, film, flickr, lens, mx, nettar, p3, p30t, pentax, photography magazine, post, praktica, retina, shutter, site, store, stuff, swap, test, thrift, tools, winder
The "Keeper" Lens Club -- You'll regret it if you sell it. vandamro Lens Clubs 95 04-06-2017 08:28 AM
Is it safe to share my personal collection of K-01 lens p0rn? elpolodiablo Pentax K-01 41 03-01-2013 11:16 AM
If you aren't using it, zip it up! The Jannie Pentax DSLR Discussion 17 09-16-2011 04:35 PM
You've got to love technology and it's mindlessness mtansley General Talk 6 07-24-2011 05:43 PM
Cityscape Got one I'd like to see what you can do with it photolady95 Photo Critique 9 06-25-2011 01:27 PM
All times are GMT -7. The time now is 08:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
