Originally posted by chickentender Holy crap. How's it shoot/handle? Looks like you could easily defend yourself with it if necessary.
It is a handful when mounted to a small body like the Super Program. Adding the Winder MEII helps a little. I should note that at 860g and 150mm length it is about the same size as other comparable zooms in its class, though a little heavier than most. When compared to current model 70-210/2.8 from Tamron and Sigma or even the FA* 80-200/2.8, it is both small and light
On the K-3, it is not too hard to handle, though it definitely benefits from proper grip, stance, and breath control at 210mm. I have been impressed with the optical quality on my initial test shots, though it is prone to purple fringing. Lateral and longitudinal CA are very well-controlled and the lens nicely sharp with good contrast.
I also recently acquired the much smaller/lighter, and much less highly-regarded Tamron 70-210/4-5.6 (158A). It is almost comical to stand the two next to each other. I am planning on doing a comparison post where I hope to redeem the reputation of the 158A a little. It is not a
bad lens and performs on the same order as the DA 50-200/4-5.6 in a slightly more compact package. I am quite happy with the 158A purchase at $30 USD. It came equipped with a PKA adapter at no extra charge.
