Originally posted by wombat2go Would like to see it.
here ya go.
This one is a normal, un moved set up. Note the copper lever at the bottom of the standard, that is my lock on shift and swing. The manufacturers knobs on side of standard, lock rise and tilt as normal.
OK, here I have shifted right, added rise, tilted down and swung to the left.
Better view of locking lever. Note that the rivets had to be removed from original standard support to allow the swing.
I hesitated to make this modification, because those rivets fastened the standard to the shifting mount.
Without those, the only supporting fastener would have to solidify and support the standard from a single point.
This shot shows shift right, rise, tilt up, and swing right. I had to add some brass washers to raise the standard above the groove that it was riveted into. I agonized for several weeks on making this mod, until I had completely visualized the entire process and how the result would work.
The locking lever, has a nut that I ground down to nearly the thickness of the copper sheet, that fits the bolt that comes up from the bottom. JB weld saved this project.
