07-28-2016, 06:07 PM   #4411
Swift1's Avatar
QuoteOriginally posted by unixrevolution Quote
I am willing to bet the 4x5 is actually lighter, too. The lenses are much smaller, and the camera is mostly air. My Super Graphic was lighter than my 6x7 by just a bit. My current 4x5 wood field is lighter by a lot! Awesome setup!
Yes... a fair bit lighter
QuoteOriginally posted by EJMzagsfan Quote
I'll have the first roll finished today. I cant get the 135mm to stop down and the cameras flacking some foam from some where, but at the price I got everything for I have no complaints.
Looks like a gorgeous kit!
07-29-2016, 04:41 AM   #4412
WPRESTO's Avatar
I'm sure the 4X5 actually weighs less than the 6X7, but there's also a psychological phenomenon at work. A small object that weighs the same as a much larger one "seems" to weigh more, that is, psychologically, the density of an object influences how we react to the weight.
07-29-2016, 05:15 AM   #4413
The Speed Graphic 4x5 and the RB67 with the chimney each weigh about 2 kg (4 pound)
The prism for the RB weighs about 0.5 kg alone.
The Graflex 2x3 Baby (left) is the lightest at about 1.5 kg
I can't take sharp photos close in with the Graflex like I can with the RB67 slr - for family photos or close in like this photo:
https://app.box.com/s/yvp08s3w4bver2iwtva8t9mbt4tque71
For distance photos, the Graflexes are OK.
E-PL1  Photo
07-29-2016, 05:57 AM   #4414
WPRESTO's Avatar
QuoteOriginally posted by wombat2go Quote
I can't take sharp photos close in with the Graflex like I can with the RB67 slr\. or distance photos, the Graflexes are OK.
Is it a problem with parallax, rangefinder accuracy, or the lens not delivering IQ at short distances?
07-29-2016, 06:20 AM   #4415
LaHo's Avatar
Heavy Artillery
My Pentax 6x7 MLU with the smc Pentax-67 300mm F4.0 attached. Great cam.
Camera: Mamiya C330 Professional
Lens: Mamiya-Sekor 65mm F3.5 (Seiko shutter)
Exposure: 1/60 @ F5.6 (Y2 filter + Pentax 49mm hood)
Film: Fomapan 400 Action dev. in Compard R09 Spezial
07-29-2016, 06:38 AM   #4416
QuoteOriginally posted by WPRESTO Quote
Hi WP,
There are a few issues.
Firstly I am tending to use the Graflex cameras to try out multiple lenses.
That means the rangefinders are usually out of service.
(My 4x5 rf is for the 135mm, and my 2x3 rf is for the 103mm
Secondly so far I don't like to use a tripod and ground glass.
When the rangefinders are out of service, the only way to focus is with the bed scales ( On the 4x5 I have added a scale for use on the other lenses)
Here is a photo where I did use the tripod and ground glass, and tilt to bring the near by fence into focus.
https://app.box.com/s/71zle4bsq15813bwvbjf
The Graflex cameras and their lenses perform OK when used like that.
A final issue when using the cameras to try various lenses, is that the bed infinity stops are not in service.
So in discussion with Apug and Dan Fromm, I have made a "jigger" for the 2x3 that allows the front standard to be accurately paralleled at infinity.
These have been used for a long time, the one I made is adjustable for various lenses. I have yet to make a longer one to suit the 4x5.
Thanks for the interest in the old cameras!
E-PL1  Photo
E-PL1  Photo
07-29-2016, 09:48 AM   #4417
unixrevolution's Avatar
QuoteOriginally posted by LaHo Quote
Very nice! I have the same strap on my 6x7, and i also own a c330 as well. The 6x7 ive had for a while, the 330 less than a month.
Which do you use more?
07-29-2016, 10:26 AM - 1 Like   #4418
LaHo's Avatar
Lately I have been using the Mamiya C330 the most. Though bulky and heavy, it is easier to bring along with a couple of lenses than the Pentax 6x7. The C330 has shown itself to be quite easy and practical to use for street shooting. Most people don't know what it is anymore, and they don't expect a photo taken from waist level.
But as a system I like the Pentax 6x7 much better. My widest Mamiya-Sekor lens is 65mm. There is also a 55mm, but none of the two are particularly wide. My widest Pentax 6x7 is 45mm, and that is a brilliant lens. I also have the newest version of the 55mm. In the long end I have the 300mm shown above and also a 500mm, but that one is pretty heavy to tug along. All together there are so many fine lenses to be had for the 6x7 system.
I have used the 300mm handheld on the Pentax 645N with adapter with fine success. The 500mm requires a sturdy tripod.
I like the Op-Tech strap very much. It really seems to be weight-reducing.
BTW, here is a street shot I took with the Mamiya C330 and the 80mm F2.8. He did not notice me at all, but had I used the Pentax 6x7, the shutter noise might have given him a heart attack:
Lens: Mamiya-Sekor 80mm F2.8 (Blue dot)
Exposure: 1/125 @ F8 (Y2 filter + rubber hood)
07-29-2016, 11:39 AM   #4419
Swift1's Avatar
I just weighed my 67 and my Busch Pressman.
The 67 with 90/2.8 and unmetered prism weighed basically the same as the Pressman and Caltar II-N 150/5.6.
Both weighed right about 5lbs (2.25kg). I didn't have the Speed Graphic to weigh but from memory it is noticeably heavier than the Pressman.
Internet research says a Pacemaker Speed Graphic and lens should weigh around 3.2kg, but I can't confirm this.
I was actually surprised that the 67 and Pressman weighed the same.
Your Speed Graphic should be capable of very good results close up, but you really need to use a tripod and ground glass focusing.
08-02-2016, 05:36 AM   #4420
vrolok's Avatar
Just got, today, these two beauties...
Cheers
08-02-2016, 09:44 AM   #4421
QuoteOriginally posted by vrolok Quote
Cheers
Is that your first LX? You're going to be blown away with what it can do, if so. I have mine out and about for the first time in a long while. I forgot how good it was.
08-02-2016, 11:04 AM   #4422
Cheers
At some point, please post pictures from and your impression of the Petri as well. I pondered buying one back in the day, but settled on a Ricoh Singlex TLS instead.
08-02-2016, 03:33 PM   #4423
vrolok's Avatar
Actually yes it is! Just a great slr
---------- Post added 08-03-16 at 12:53 AM ----------
Sure, I will but it will take some time, though. Great feeling holding it.
The one I have is in excellent condition, with its 55/1.8 and original ever ready case. Mechanically, it looks and sounds fine. The metering works well too, though I think it overexposes by about 1 EV (I have to check it better). I have used a zinc air battery that fits in just perfectly. Light seals need to be replaced (I will do it tomorrow). I don't know how to change the mirror bumper since there apparently is no easy access to, oh well, will see. The one and only thing that I dislike is a very pale haze inside the viewfinder.
Anyhow, it is a simple camera. Full manual... but also has shutter priority programme! From 1/500 to 1/2 s, + B. Up to 800 iso and self timer.
08-03-2016, 01:03 AM - 3 Likes   #4424
Jonathan Mac's Avatar
I love taking viewfinder pics of my Yashica Mat 124Gs
IMGP2764a
by Jonathan MacDonald, on Flickr
08-03-2016, 05:45 AM   #4425
QuoteOriginally posted by Jonathan Mac Quote
IMGP2764a
The Yashica TLRs are suprisingly capable cameras. Especially the Yashinon lens models. I love both of mine, I have a Yashicamat 124 and a Yashica 635. The latter, I think I am keeping for good. The other is getting traded to someone for some other gear. I have the Mamiya TLR now and I simply don't need 3.
645n, af, bronica, camera, chris, ebay, eric, f2.8, fa, film, flickr, lens, mx, nettar, p3, p30t, pentax, photography magazine, post, praktica, retina, shutter, site, store, stuff, swap, test, thrift, tools, winder
The "Keeper" Lens Club -- You'll regret it if you sell it. vandamro Lens Clubs 95 04-06-2017 08:28 AM
Is it safe to share my personal collection of K-01 lens p0rn? elpolodiablo Pentax K-01 41 03-01-2013 11:16 AM
If you aren't using it, zip it up! The Jannie Pentax DSLR Discussion 17 09-16-2011 04:35 PM
You've got to love technology and it's mindlessness mtansley General Talk 6 07-24-2011 05:43 PM
Cityscape Got one I'd like to see what you can do with it photolady95 Photo Critique 9 06-25-2011 01:27 PM
All times are GMT -7. The time now is 08:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
