Show Printable Version 9444 Likes Search this Thread
09-04-2020, 07:30 AM   #7051
Jonathan Mac's Avatar
QuoteOriginally posted by womble Quote
I've been updating my website and thought I would post some of the photos here too.
Pentax AP par Kris Lockyear, on ipernity
Pentax K2DMD par Kris Lockyear, on ipernity
Pentax K par Kris Lockyear, on ipernity
Ondu pinhole par Kris Lockyear, on ipernity
Minolta 7000 par Kris Lockyear, on ipernity
I didn't know you used AF Minolta stuff - how do you find it? It can be had quite cheaply these days but I've read bad things about the build quality. I use old SRT Minolta cameras and they're wonderful but never tried their AF stuff.
09-04-2020, 07:46 AM - 5 Likes   #7052
womble's Avatar
QuoteOriginally posted by Jonathan Mac Quote
I don't use it very much. The 7000 has a back story. My friend Kate had Raynaud's and needed a camera she could operate with her badly damaged hands, and the 7000 was ideal for her. Sadly, she died in 2000 at the age of 38. Many years later her father, Tony, gave me her camera which by then was covered in a thick layer of dust, and still had a half-used roll of film in it from before she died. It cleaned-up nicely and works fine. I don't use it very often, preferring my manual focus Pentaxes, but I make a point of running at least one roll of film through it every August. The 35 to 105 lens is really quite sharp, and I have had some nice photos from it. This is one of my favourites, a picture of Tony looking over the parapet at the River Mimram flowing below.
Looking for holly par Kris Lockyear, on ipernity
09-04-2020, 12:38 PM - 4 Likes   #7053
womble's Avatar
<begin nerd warning>
Some time ago I purchased a Pentax copy stand P. This is a collapsible copy stand that I thought might be useful for the work I do. Here is the beast:
copystand (1) par Kris Lockyear, on ipernity
copystand (2) par Kris Lockyear, on ipernity
copystand (3) par Kris Lockyear, on ipernity
copystand (4) par Kris Lockyear, on ipernity
Although I have had it for a few years, I'd never used it in anger but I decided to use it this afternoon. I had forgotten that one reason I hadn't used it was that my K-3 did not fit on the plate on the focus rail. Arrgghhh. Then I remembered that I have a focus rail on which the K-3 does fit. Curious. I removed the one from the copy stand to find it has two pins to locate it. These match those on my other rail perfectly and so I was in business. When I had finished I compared the two focus rails. The one on the right is the one from the copy stand, the one on the left is the separate one I had purchased at another time.
focus rail par Kris Lockyear, on ipernity
As you can see, one has a much deeper attachment plate, and the rail mechanism is reversed. How very curious. I suspect that my copy stand is an early model (Phil has a P-III) and I wonder if the change in the attachment plate reflects larger cameras, or perhaps one with a motordrive? Whatever the story, I'm glad I can now use my stand with my digital SLR by swapping out the two rails.
<end nerd warning>
09-04-2020, 01:19 PM - 1 Like   #7054
kevinWE's Avatar
I own the Minolta XTsi, it's not the greatest build, it's all plastic, but it still works as it should after all these years and my photos are just fine even while using the kit lens. The camera is as light as a feather due to all the plastic. The XTsi is kind of built like my Sigma SA-7n. Just treat the camera right and it will outlast you.
Here's an image of my XTsi I just shot on my desktop.
09-04-2020, 03:02 PM - 1 Like   #7055
ismaelg's Avatar
That is the kind of story that makes some items so special. Thanks for sharing the story behind it.
Thanks,
09-04-2020, 03:40 PM   #7056
redrockcoulee's Avatar
My wife still has her's. With the F 70-210 lens. 8t doesn't get any use as she shoots either toy cameras, tin cans or her Hasselblad SWC
09-05-2020, 01:44 AM   #7057
Lord Lucan's Avatar
Some time ago I purchased a Pentax copy stand P. .... one reason I hadn't used it was that my K-3 did not fit on the plate on the focus rail.
What stopped it from fitting?
09-05-2020, 02:09 AM - 1 Like   #7058
womble's Avatar
QuoteOriginally posted by Lord Lucan Quote
If you look at the last photo with the two focus rails you can see that there are two metal lugs on the bottom (as seen in the photo) of the attachment plates. These are to keep the camera body square to the plate and thus, when on the stand, vertical to the baseboard. On the one from the copy stand the distance between the two lugs and the attachment screw is not deep enough to accommodate a dSLR. On the other focus rail, the plate is large and the attachment screw is in a longer slot so you can place the camera body against the lugs and then fit the attachment screw.
09-05-2020, 02:38 AM   #7059
Lord Lucan's Avatar
Interesting. It sounds possible to remove the rubber padding, file those lugs down somewhat, and stick the rubber back on afterwards. It may be that the second bracket was a later version when Pentax realised that the first one was too restrictive. I level (using a tripod) with the aid of a small spirit level placed on the back of the camera.
09-05-2020, 03:11 AM - 4 Likes   #7060
womble's Avatar
Yes, one could easily remove the lugs, but as I have a rail that works I'd rather not damage the copy stand more than it has been already. I've spent many years photographing stuff using a tripod and a spirit level, but when you have a lot to do and they are all different sizes, a copy stand makes life much easier. I have an adjustable "finds stand" too, which means I can move the object up and down rather than the camera!
Me taking photos par Kris Lockyear, on ipernity
Best wishes, Kris.
09-05-2020, 06:03 AM   #7061
WPRESTO's Avatar
<end nerd warning>
I have just the Pentax close-focus rail, although there were many times when I was tempted to purchase the collapsible copy stand back ing the 1970-80's when doing a lot of specimen photography at remote locations.My unit has the long slot.
I have two complaints with the Pentax close-focus rail:
1) The fitting is not tight, there's a lot of loose wiggle when the rails are not locked, so you dare not take your hand from the focus knob when using one in vertical orientation or the rig will immediately drop to the lowest position.
2) The lock lever and the rack-&-pinion knob are on the same side making it awkward at best to lock the rail after getting the camera into focus.
I have multiple rails now, including the old Pentax unit. Except for size, almost all the others are superior to the Pentax unit, but none of them are perfect.
09-05-2020, 06:21 AM - 6 Likes   #7062
womble's Avatar
QuoteOriginally posted by WPRESTO Quote
I have just the Pentax close-focus rail...
I'll admit the one I have was bought because it was the Pentax one... I've often looked at others, and having one with a more subtle racking/locking set-up would be good. Its OK if you aren't working at minimum focusing distance, but if you really want to set the lens to a specific value and focus by moving the camera, its not very easy with the Pentax one. More extreme close-ups by reversing the lens, etc., are equally difficult.
And talking of close-ups, I took this image this morning. Cross-posted with the lens fetish thread.
SMC Pentax 50mm "K" f/1.2. par Kris Lockyear, on ipernity
09-05-2020, 07:17 AM   #7063
tonyzoc's Avatar
QuoteOriginally posted by kevinWE Quote
I've got one of these with the 35-80 and Minolta flash. My brother-in-law gave it to me when gave up on film. It's not a bad camera at all...to bad it's not worth much.
09-05-2020, 10:37 AM   #7064
kevinWE's Avatar
QuoteOriginally posted by tonyzoc Quote
Yep, I think you can find the camera and lens kit for under 50.00 USD on the bay, in good clean working condition.
09-05-2020, 02:07 PM   #7065
Now that is funny, my brother in law is giving me one.
I have a few different models of these and they are all clean, great working cameras....that are heading for ebay. I don't know if I will get rid of one though. I cannot remember what model off the top of my head, but when I first picked it up, it felt like an extension of my hand. Best ergonomics of any camera I have held, and the auto focus is super fast, quiet, and the viewfinder is large, bright, and super clear. I bought a battery for it (most expensive battery purchased in a long time) stuck an old, not cared for roll of film in it, and now want to see what a new roll of film will do.
645n, af, bronica, camera, chris, ebay, eric, f2.8, fa, film, flickr, gear p0rn post, lens, mx, nettar, p3, p30t, pentax, photography magazine, post, praktica, retina, shutter, site, store, stuff, swap, test, thrift, tools, winder
The "Keeper" Lens Club -- You'll regret it if you sell it. vandamro Lens Clubs 114 04-06-2023 10:37 PM
Is it safe to share my personal collection of K-01 lens p0rn? elpolodiablo Pentax K-01 41 03-01-2013 11:16 AM
If you aren't using it, zip it up! The Jannie Pentax DSLR Discussion 17 09-16-2011 04:35 PM
You've got to love technology and it's mindlessness mtansley General Talk 6 07-24-2011 05:43 PM
Cityscape Got one I'd like to see what you can do with it photolady95 Photo Critique 9 06-25-2011 01:27 PM
All times are GMT -7. The time now is 02:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
