03-27-2013, 11:03 AM   #1
nkuce's Avatar
Pentax P30 + ILFORD HP5
I recently got a used camera PENTAX P30;
The manual says I should use DX film, or the camera will default to ISO 100. My film is Ilford HP5 400/27 and is labled 'DXN' --
Do the "N" mean anything I should worry about, or can I use that film without worry?
any help appreciated!
Ilford HP5 400/27 > http://www.ilfordphoto.com/Webfiles/20106281054152313.pdf
03-27-2013, 11:17 AM   #2
blackcloudbrew's Avatar
No idea what the N is for but DX is DX. I think it would be hard to find any new film that is not DX. I don't know the P30 but most cameras have a way to manually enter the ISO in case the camera doesn't recognize the film from the DX encoding on the canister.
03-27-2013, 11:17 AM   #3
tlong423's Avatar
I have used very recent HP5 rolls in a Pentax P3N (essentially the same camera). It worked fine.
03-27-2013, 11:55 AM   #4
maxfield_photo's Avatar
The DX code is the silver bits on the side of the film canister. Inside the camera body you will notice some contacts where the film canister sits, those read the DX coding. Like blackcloudbrew said, it's hard to find film that isn't DX coded these days, the only time you would probably encounter it is when you use generic canisters and bulk load your own film.
If you want to push or pull your film though, this becomes an issue if the camera doesn't offer a way to override the DX coding. I suppose you could cover the coding with a piece of electrical tape, and that would give you a default pull of 2 stops in the case of ISO 400 film. If you wanted a different push/pull factor, you would just need to shoot in manual and remember to over or under expose every frame on the roll by the same amount.
03-27-2013, 12:15 PM   #5
carrrlangas's Avatar
DXn stands for Digital indeX Number:
DX number - Wikipedia, the free encyclopedia
apart from the DX code, (black and silver squares that are read by the camera) the DXn adds a barcode and number for the film proccesing machines that can read the bar code..
But the DX code will work the same.
03-27-2013, 08:14 PM   #6
QuoteOriginally posted by blackcloudbrew Quote
I have several rolls of Rollei Retro 80s (bought last year) in my refrigerator that lack DX encoding. This is not unusual for specialty emulsions or art films.
03-27-2013, 11:35 PM   #7
IIRC DX coding came in somewhere near the early1990's so it's quite likely that film from the 1980 would not have it. That was why I said new film. However, I figured that i might be wrong for something like specialty films.
03-28-2013, 07:30 AM   #8
DX encoding (as with the P30) dates from the early 1980s and Rollei Retro 80s is a newer film (only been available for about 5 years). The "80s" part of the name refers to the nominal ISO film speed. Your point is well-taken though. Even the "brown box" film I got from Four Corners Store has DX. I don't know why Maco/Mahn did not put the DX codes on some of their Rollei-labeled films.
As for the P-series cameras...It is a crying shame that they don't feature manual film speed override. They are sturdy and well-designed and as far as I am concerned, the DX limitation is the only drawback to ownership.
03-28-2013, 08:05 AM   #9
Thanks for those clarifications!
04-09-2013, 06:17 AM   #10
I had to sell my P30T because it does not allow DX override. I bulk load 90% of my B&W 35mm film, and push the other 10% for more contrast. Ended up going to an MZ-S in the long run.
04-09-2013, 06:36 AM   #11
QuoteOriginally posted by brofkand Quote
Perhaps a bit late.. But I found a way to fool the DX reader by using a dremel on the DX nof the film cannister...
https://www.pentaxforums.com/forums/pentax-film-slr-discussion/200819-pushing...rst-timer.html
04-11-2013, 08:30 PM   #12
I realize you can grind off the paint to make your own DX code, but I didn't want to fool with that honestly. All of my film is bulk loaded and I often change up the ISO as necessary. Sometimes I push Delta 400 to 3200, or pull to 200, or rate Foma 100 at 50, to affect contrast and tonality (and also appearance of grain). It would be too much to keep track of which reloadable cassettes I've modified to read at what DX code. It was easier to get a different camera honestly.
04-11-2013, 10:00 PM   #13
Jonathan Mac's Avatar
I use tin foil, paper and glue to make my own DX code labels for when I want to push (not that often). It's very easy.
I think you used to be able to buy them but now that film is less common, it may not be the case. Anyway, my way will surely be cheaper.
I agree the P30 series cameras are great, and with the above treatment to get around the DX limitation, they are my most-used cameras, and I have an MX, a KX, an ME Super...
04-12-2013, 10:45 AM   #14
Unfortunately, this is the ultimate solution.
05-09-2013, 11:37 PM   #15
nkuce's Avatar
Thank You ALL very much for your helpfulness!
camera, film, hp5, ilford, p30, pentax
Pentax P30 - Wind Lever Problem. nat.mitch Troubleshooting and Beginner Help 3 10-28-2012 06:43 PM
Ilford HP5 400 temperature bnishanth Pentax Film SLR Discussion 8 03-02-2009 03:50 PM
Ilford HP5+: round 2, pushed to 1600. CSoars Pentax Film SLR Discussion 21 02-24-2009 09:20 AM
Ilford HP5 shots Gooshin Pentax Film SLR Discussion 9 01-17-2009 01:50 PM
Shot some Ilford HP5 Plus (2 sample shots) CSoars Pentax Film SLR Discussion 15 01-12-2009 10:24 AM
All times are GMT -7. The time now is 02:08 AM. | See also: NikonForums.com, part of our network of photo forums!
