05-02-2013, 05:17 AM   #1
patjp's Avatar
Velvia 100 vivid or wild colour
I am looking for a bit of advice about Velvia 100. I had never used it before and after scanning I got pictures like this.
I have heard Velvia colours are vivid but is this typical? I can easily adjust the colours while scanning but if I am shooting Velvia I want it to look like Velvia.
Any pointers would be welcome as a few of us on the Single in Challenge are scratching our heads.
Patrick
An unprocessed DA15 shot of the same scene
05-02-2013, 06:06 AM   #2
blackcloudbrew's Avatar
I like the film colors, I think your DA15 is off...not! Sorry, no idea. I would ask if the film was expired or not.
05-02-2013, 06:08 AM   #3
Just to be sure, is this what the slide looks like when viewing it on a color balanced light box? Just trying to eliminate the scanner from the equation.
05-02-2013, 06:09 AM   #4
Digitalis's Avatar
No that magenta /red shift is not "normal" for velvia. If the film has been stored incorrectly, or if it is expired or the chemistry* used to develop it isn't reasonably fresh there are going to be problems. Sadly, there aren't many E6 transparency labs left out there.
*it is possible however unlikely that the film was accidentally cross processed - this nearly always causes some pretty weird colour shifts from film. Cross processing is commonly done by processing E6(transparency) film in C41(negative) chemistry - though you can go the other way around, the effect isn't quite as pronounced.
05-02-2013, 06:34 AM   #5
patjp's Avatar
Thanks for help. I think it looks like a scanning error on my part rather than a lab error. The film was not expired either.
I never thought to use a light box. I don't have one but using my computer screen I don't see such an extreme red shift.
05-02-2013, 06:42 AM   #6
Digitalis's Avatar
QuoteOriginally posted by patjp Quote
well there you go...just hope your monitor is set to D65....
05-02-2013, 07:45 AM   #7
Distinct advantage of slides is you can visually confirm the colors.
05-02-2013, 07:51 AM   #8
Douglas_of_Sweden's Avatar
The E6 itself also has two separate developers...if they up the time or temperature on them you can get some quite weird results. Know from own experience....have had some rolls come out green or pinkish or something like that.
05-02-2013, 12:08 PM   #9
Patrick
So...what does the slide look like? Tune the scanner to match the slide.
That being said, Velvia is known for over-the-top color rendition. Sometimes this works (think red rock areas of the American Southwest) and sometimes it doesn't (most weddings).
05-03-2013, 12:29 PM   #10
gofour3's Avatar
That’s the reason I mostly shoot slide film as I can view the finished images on my light table with a photo lupe.
Getting scanned images to look like the original slide is another issue.
Phil.
05-03-2013, 12:34 PM   #11
Reliant K1000's Avatar
My experience with Velvia is when it first came out, but I found it to be very vivid colors, not like you experienced.
05-03-2013, 03:18 PM   #12
patjp's Avatar
QuoteOriginally posted by gofour3 Quote
After a month of shooting Velvia and Provia I now only want to shoot slide film. The negatives look so wonderful.
05-07-2013, 03:47 PM   #13
Velvia 100 favors the red end of the spectrum but not as much as is seen with your shot above. My shots of the Grand Canyon were ruined by it. Beige rocks were turned reddish. It looked surreal. However my Colorado shots with red flowers and green mountains looked great. Velvia 100f and 50 look very different from the 100. You really have to be careful where you use the V100.
colours, flickr, velvia
Braun Paxette Electromatic (Wittnaeur Automaton) with Velvia 50/100 anbuzim Pentax Film SLR Discussion 5 09-27-2012 02:55 AM
Velvia 100 Discontinued? MetaD Pentax Medium Format 15 08-02-2012 03:11 AM
Fujichrome Velvia 100F (all sizes) and Velvia 50 4"5" discontinued RKKS08 Pentax Film SLR Discussion 3 07-27-2012 05:51 AM
Where to develop Fujichrome Velvia RVP 100 henryjing Pentax Film SLR Discussion 9 04-18-2010 04:10 PM
DA 40mm Ltd... on 35 mm Fuji Velvia 100 knyghtfall Pentax SLR Lens Discussion 8 04-26-2008 05:47 PM
All times are GMT -7. The time now is 12:46 AM. | See also: NikonForums.com, part of our network of photo forums!
