05-22-2013, 01:36 PM   #1
ME Super non definite aperture adjuestment
Hi,
Sorry about the odd title but I found the 'issue' hard to sum up.
I have noticed that when I adjust the aperture on my lenses when they are not on the camera there is a definite click between stops. When fitted to the camera when I decrease the aperture it's fine. When I try to increase the aperture its much stiffer and there is no definite click between stops.
Lens 1 is a SMC Pentax-M 1:1.7 50mm
Lens 2 is a Super OZECK Auto Tele Photo Close Focusing MV 1:2.8 f = 135mm
Do you think this is a problem with the lenses or the camera?
Thanks
05-22-2013, 01:58 PM   #2
When you turn the ring one way (for wider aperture) there should be slightly more resistence than when you move to choose a narrower aperture. With the lens off the body you should be able to manually slide the coupler lever. Resistence should be minimal.
05-24-2013, 03:05 AM   #3
With the lenses off the camera the couple levers move with very little resistance and I can see the aperture's moving as expected.
When the lenses are on the camera, especially the 50mm, if I move the ring from the widest to narrowest then back again everytime I move it to the widest it get stiffer and stiffer. To the point where something feels jammed.
05-24-2013, 05:51 AM   #4
As Steve noted, the aperture setting lever on the lens moves a spring-loaded "follower" lever in the camera to tell the meter what aperture is set. It sounds like the follower in the camera is binding. You might find an ME Super repair manual on the Web to figure it out, but I'd recommend sending it to Eric Hendrickson for a full Cleand Adjust Lubricate service. He's not expensive, and it would work like new for another 20 years.
05-24-2013, 05:57 AM   #5
Hi,
Thanks for the feed back.
I'm in the UK but have found, via this forum, a Pentax service shop that I'm going to send the camera to.
aperture, camera, click, lens, lenses, stops
Q adaptor aperture accuracy with non A lenses? Lowell Goudge Pentax Q 3 03-28-2013 02:44 AM
problem with pentax me(non super) Carstenschertzer Pentax Film SLR Discussion 3 01-01-2013 11:32 PM
Help: Pentax ME Super stuck to largest Aperture Carlota_Nonnumquam Pentax Film SLR Discussion 11 11-22-2011 04:03 PM
Pentax ME Super - Aperture Lever Problem ioszhka Pentax Film SLR Discussion 9 02-10-2011 03:30 AM
ME Super and aperture <-> light meter orbisvicis Pentax SLR Lens Discussion 4 02-17-2010 08:51 PM
All times are GMT -7. The time now is 12:38 PM. | See also: NikonForums.com, part of our network of photo forums!
