Picture 1 : Scanned straight out of negative.
Picture 2: treated with curves from photoshop
Picture 3: Resized to reflect actual person's width.
Hello, so i've shot my first film roll....and need some help diagnosing some things.
1. Why does the original scans from negatives look sooo...flat? Is dodging and burning always required? Its either everything's overexposed a tad, or everything's under exposed a tad...but there is no 3D quality to it - except the dof. Compare picture 1 and 2, after a curve adjustment in photoshop.
2. Film has more dynamic range than digital. However, without doing the darkroom process myself - it seems like I wont be getting this advantage film has over digital. The camera place scanned the picture at lower resolution, and in jpeg. Basically, the huge range of dynamic range was left behind with the negative - since this is akin to taking an iphone photo of a davinci masterpiece. Is there no other way around this other than printing myself?
3. Unrelated to film, but i thought I should ask this to the more experienced members. I always like the effect of wideangle lenses in distorting people and making them taller (as in glamour shots). However, every single seminars/workshop I attended have stressed the use of tele lenses to compress and making people slimmer. I see the effect of compression to the background, but I dont think tele lenses really help with the subject itself. No matter - because I dont use a prime when shooting, i am generally unaware of what focal length i was using to get the effect i wanted.
However, with the film camera yesterday - i shot prime. This was my 125 voigtlander at work. Picture 3 shows the actual body proportion of the model. Actually, i think she is even thinner than that. What gives? I knew that historically my results never were similar to the workshop speaker's conviction of tele lens performance - but i was never bothered until now.
4. What does the brand of film (I was using ilford bw) do to the picture?
5. Can anyone identify the 3 semi circle blotches on the picture? it probably showed up in one other shot of the whole roll..i think. But as i havent done curves adjustment to each other...i can't tell for sure.
Thanks for the help!
