07-12-2013, 05:57 AM   #1
DIY developing creativity
I am pretty new to film, started this year. My focus is family pics, mostly documentary / life pics.
I have successfully done 3 b&w rolls and 5 c41.... Pretty happy with the results so far.
In my learning, I have some stuff I want to try / have tried:
1. Over exposing and then developing normal time: tried this on tri-x and loved it. Shot at 200 and developed at 400. I think some shots were a bit too much so will probably settle on 300 when I want this look, at least on tri-x. Next up is portra 400 for this method.
2. Under exposing and then developing longer (a normal push): haven't done this yet on portra or trix but I accidentally shot some ektar @400. loved the look for beach shots but people i can do without. i do love the pushed film look. Will try it in b&w and portra 400 soon.
3. Normal pull: don't think I would try this as I like option 1 so much
4. Under exposing and developing normally: seems like my under exposed shots that were in a normally developed roll all look bad so I think I will stay away from this.
Any other ideas I should try? I am most excited to push the portra stuff but am I missing anything else from a developing / exposure standpoint?
I am super happy with film so far..... These forums have been very helpful. I will post up some pics eventually but most are my kids and I don't want them all over the Internet
07-12-2013, 07:24 AM   #2
blackcloudbrew's Avatar
Are you developing these yourself? If you are doing the b&w film, I'd suggest an exercise I did in my class last spring. I took a 36 exposure roll of film, I think it was Tmax 100 but that really doesn't matter. If you set your camera on a tripod and point it towards a reasonably complicated subject (with lots of contrast and shadows), you take a series of of 6 images 6 times 2 stops under, 1 stop under, normal, 1 stop over, 2 stops over, and a blank with the lens cap on. Repeat that 6 times. Now comes the hard part, in the darkroom. you remove the film from the can and cut it into 3 equal lengths. Put each of those into a developing container. Then...using the same developer process one 50% under the normal developer time, one at the normal developer time, and one 50% over the developer time. When dry these negatives will provide at least one good 5 image strip showing the effects of under, normal, and over developing the same image / film + the affects of under/normal/over exposing as well all on the same subject.
Do you have to do this? No, but it can give you some insights on the way things work - shadows/hightlights etc.
07-12-2013, 07:34 AM   #3
Good idea. I have a classic b&w photo book which does that same thing more or less so i can see what that looks like. What is a new twist in all this is how well do things scan and what latitude do I have in the digital workflow.
One of the main reasons I started into film was the alien skin software 'exposure'
The over exposed scans are super easy to work with after scanning, the under exposed are nearly useless....
07-12-2013, 08:13 AM   #4
maxfield_photo's Avatar
If you like overexposing coupled with normal development, you might like "stand" development. I've only tried this with Rodinal (or Rodinal alternative), but it works great, I couldn't believe it. Essentially you use a weak solution of developer, and just let it sit until it exhausts itself. 1:100 for one hour, or if you're brave 1:200 for two hours. Invert once every 30 minutes to prevent bromide drag. Then just stop and fix normally. You can use a water stop bath. I've been using Photo Formulary TF5 for my fixer, followed by Photo-Flo during the rinse.
07-12-2013, 12:53 PM   #5
carrrlangas's Avatar
pics or it didnīt happen!
07-13-2013, 06:57 AM   #6
Sorry my scanner is down at the moment, and I have a week's worth of digital photos to edit, but here's essentially the technique I'm using. I usually pull instead of push, but because the developer exhausts itself on the highlights, you don't have to worry about N+1 or N-1, it's all just the stand equivalent of "N". I think you get a bit more punch from traditional development, but stand works great for hybrid process, or you can correct with contrast filters in the darkroom.
film, look, pics, portra, shot, shots, stuff, tri-x
Stand Developing Pioneer Film Processing, Scanning, and Darkroom 20 12-14-2011 08:44 AM
Abstract Some Minor Creativity Borne of Boredom jsherman999 Post Your Photos! 9 12-09-2010 01:36 PM
Creativity ? tony13 Troubleshooting and Beginner Help 33 03-19-2009 10:17 AM
Creativity... benjikan Photographic Technique 2 10-12-2007 06:53 AM
All times are GMT -7. The time now is 11:48 AM. | See also: NikonForums.com, part of our network of photo forums!
