Originally posted by Lowell Goudge I have 3 film bodies to go with my *istD and K10D, these are
KX, Ricoh XR-2s and PZ-1.
The KX is a fully manual camera, with matched needle metering.
The Ricoh XR-2s is a poor man's K2DMD, it has identical control and view finder layout to the KX, but as opposed to the fabric, mechanically times horizontal shutter, which tops out at 1/1000 and has 1/60 flash sync, the XR-2s has a metal blade, electronically controlled vertical shutter, with 1/2000 and 1/125 flash sync. It also supported Apature priority automatic mode with center weighted metering. The Ricoh bodies had a nice feature, a diagonal split image, much better than horizontal. The XR-2s also supports a 2.2 fps motor winder which I also have. These 2 made a great pairing, since they were identical to operate.
My PZ-1 however is light years ahead of these full manual bodies. It has a 3 FPS built in motor winder, TTL flash, spot metering along with matrix metering, is a full AF body, but unlike the multititude of compatc 35mm SLRs that pentax made, this is a full sized ALL metal frame with reienforced polycarbonate body. From the controls point of view, if you like a K10D, this will be very familiar to you, right down to dual thumb wheels.
Of the 3, I would have to say the PZ-1 is the best option, and same for you. This body can function in flash mode with every lens using TTL flash, it can run all automatic modes of the crippled KAF-J mount lenses, and with the exception of HSM lenses can work every lens that pentax ever made, in auto modes, manual modes Apature priority modes, plus autofocus with an acceptable accuracy and tracking capability.....
The only problem I have with the PZ-1 is that it is so similar to a DSLR, that I instinctively look at the back of the film door waiting for the digital preview to appear after I take a shot.
As corrected by Chris, 1/1000 not 1/2000 sorry.
As to build, I agree not as well constructed as pentax cameras, especially poor power connection when heavy lenses on camera and mounted using camera tripod socket.
For the OP
They are still capable cameras and much more common than a K2DMD which is quite rare. Aside from this point, if you have the option of PZ-1p or K2DMD, unless you are purely going to collect cameras, the PZ-1p is technically a
much better camera, and given your current lens line up and bodies, much more use to you.
