01-05-2014, 12:02 AM   #1
Can't set film speed on SP500
Hi I've a Spotmatic SP500 that I can't set the film speed. When I take and pull up on the shutter speed dial and try to turn it to set the ASA it only turns the shutter speed dial to another speed. So it' always set at 200 ASA and I've never used the camera as I always shoot high speed 800 ASA film. Does anyone out there know what would make the film setting not turn when the knobs pulled up. I've several other Spotmatics and two K1000's and have never had a problem like this with them. Please HELP ME !!!.
01-05-2014, 12:39 AM   #2
arnold's Avatar
It appears the ASA ring is not disengaging from the speed setting mechanism. Try it at different speed settings, it may unjam.
01-05-2014, 01:00 AM   #3
hks_kansei's Avatar
Try pushing down on the shutter speed knob with one spare finger while lifting and turning the ring with two others. (two hands easiest)
it may give enough resistance to turn the film speed ring without alos turning the shutter speed. Hopefully it's just a little sticky since it's an old camera, and that may loosen it.
If not, it may need to be pulled apart and cleaned out.
01-07-2014, 02:59 PM   #4
QuoteOriginally posted by arnold Quote
Thank you so much for your advice will try out.
01-07-2014, 03:00 PM   #5
QuoteOriginally posted by hks_kansei Quote
asa, film, shutter, sp500, spotmatic sp500
Can't set aperture on FA 50mm 1.4 VVisser Troubleshooting and Beginner Help 8 01-13-2013 06:34 PM
Can someone humour a film noob on the current price variations of film SLRs? Codazzle Pentax Film SLR Discussion 18 11-19-2012 09:10 PM
film speed on a k1000 BradleyDoom Troubleshooting and Beginner Help 7 04-10-2012 08:31 PM
K and M lens-speed won't set bjake Troubleshooting and Beginner Help 4 12-20-2011 10:27 AM
Can't get to 1/180th sync speed using Cybersync Triggers on a K-x noahpurdy Pentax Camera and Field Accessories 8 03-18-2010 06:38 AM
All times are GMT -7. The time now is 01:45 PM. | See also: NikonForums.com, part of our network of photo forums!
