I'm glad to hear that it is working better.
Note for later in your endeavors...
... in the above image where it read "... this arm is working smooth..." is an important action in the cycle to reset the shutter.
Certain cases where the camera has some sticky or dried out part, the mentioned part will encounter a failure to complete the travel and will not let the advance stroke to reset or catch the shutter cocking arm... one common symptom is the winding-on with non-firing shutter.
If the camera is exposed to a mostly dry environment, then you see little more success in operating it after it is stuck.
If the camera is exposed to a lot of humidity, then a likely gooey insides and will cause the rubber bumpers to be sticky and sluggish.
Certainly a CLA is a good thing for the future.
